flymo
I'll be likely travelling from either Guildford or Woking to Bexleyheath on Monday 23, probably early or mid afternoon. This is a single journey only, no return needed. Looking online there is a single ticket via Waterloo at about 14.10 or 16.50 via Waterloo / Waterloo East.
Looking at the fare zone map I see that both Surbiton and Bexleyheath are within the Oyster PAYG area so at the moment I'm looking at getting the train from Guildford / Woking > Surbiton for about 6 or 7 pounds - no problems there. I am then looking to exit the barriers with the ticket at Surbiton then use my PAYG Oyster to re-enter at Surbiton then go via Clapham Jn > Denmark Hill > Bexleyheath. The fare on the single journey finder is listed as 2.50 off peak or 3.90 peak.
My question is, when using Oyster is there a minimum balance I would need to make the ticket valid and use the routeing I mention above (I think I have about 4.00 on at the moment but will check before travel) and are there any route validators at either Clapham Jn or Denmark Hill (or both !!) that I need to use to confirm my routeing.
As you can maybe tell I'm not used to Oyster yet and would appreciate any advice in advance.
Ta very much.
Ta very much.
