GWR mainline blocked at South Brent/Ivybridge
Essexman
15 Mar 2011
The line is blocked at South Brent (some reports say Ivybridge) this morning due to 'river has breached the railway'.
The rivers off Dartmoor run in valleys well below the railway on this stretch of line.
Could it be that the Avon has burst its banks and the base of the viaduct pillars are under water or perhaps a smaller stream that's closer to the level of the railway?
richw
10 Jun 2010
Liskeard
River Erme is the offender according to Plymouth live. That runs almost through Ivybridge town centre
Essexman
15 Mar 2011
But crosses the railway under a big viaduct north of the town centre.
GWR have just said lines have reopened.
InOban
12 Mar 2017
Danger of scour? ie undermining the base of the piers.
800001
24 Oct 2015
The river hadn’t breached, but had reached the closure marks on one of the bridges. This needed inspecting by diving engineers in daylight.
Taunton
1 Aug 2013
The line must be a good 100 feet above the river there. Here they are :
800001
24 Oct 2015
It doesn’t matter how high the bridge above the water is, if the water reaches a level that the deem ‘dangerous’ then the bridge needs inspecting.
As @InOban mentioned above the possibility of ‘scouring’ is the most likely reason.
And to confirm it is Brent Viaduct, also known as Lower Bridge that was the culprit.
Sleepy
15 Feb 2009
East Anglia
More issues with this ? 2345 Sleeper ex Paddington to terminate at Exeter tonight, as is Up working (Plymouth)
Essexman
15 Mar 2011
The line was closed again his morning but is now open again however disruption expected until 14.00.
If only there was an alternative route open from Exeter to Plymouth.
