How did it go, tried it out yet?
Finally it’s time for a kiln update.
With the helpful advice above and a bit more research I programmed in a firing cycle, we filled it with some pots, pressed start and…. Nothing.
Ah.
I rechecked everything and it was just completely dead. So I phoned up our local clay supply place and they gave me the number of a company in Plymouth who repaired kilns. I sent them a video of it and they sent a chap out to look at it a couple of weeks later and this was what he found:
1) The kiln had been upgraded at some point with more powerful elements.
2) It originally had the controls on the actual unit and when it was upgraded they blanked that off and replaced it with the ST315 controller mentioned above which shows what it’s currently doing/the temperature it’s at etc.
3) It had a loose wire in the controller hence it not working.
4) The 13amp switched fuse that we’d fitted would very much not cut the mustard as the kiln had been upgraded and would (I think) be drawing the best part of 30 amps now!
5) The kiln works though and the chap programmed in a firing cycle for me and explained how it functioned.
6) He suggested that we only fire it when we can keep a close eye on it. So no going off to the beach for the day if it was running…
So the next free weekend we had, we loaded it up and pressed GO!
It climbed up to 600 degrees C slowly and at that point we were told to cover the vent at the top as any moisture etc would have escaped.
Then it climbed fairly rapidly but at reaching 1100 degrees C it threw up a fault code (error 7) saying that the temperature around the unit was too high. It was getting late at that point so we just switched it off.
The next evening once it had fully cooled we examined the pots and to be fair they seemed pretty well fired (we’d set it up to go to 1240 degrees C).
Obviously some of this is trial and error though, so we had another go yesterday after Mrs C had glazed those same pots.
Yesterday the same thing happened but at around 900 degrees this time. I’d moved the control unit out of the booth a couple of days ago as when I’d phoned the kiln chap again he’d suggested that the controller was possibly too near to the kiln and it wasn’t happy with the heat around it. It’s now mounted on a bracket on the door though and it still did it…
Once the kiln drops down to 600 degrees after the error code it fires up again and starts to climb back up, having handled the controller though I think I might have worked out what’s happening. I think it’s trying to ramp it up too quickly and the electrics in the box are getting too hot. I’m going to adjust the ramp settings for the next time we fire it as I think that might cure the problem, but I’m pleased to report that despite the issues last night we did eventually get it up to 1240 degrees C and complete the program!
Obviously you can’t open it until it’s all completely cooled down as everything will crack, but here’s Mrs C’s first properly fired pots!
This has all been quite the learning process but I think I’m starting to understand things now. Some of the ones we fired she actually made a while ago and she’s been making better stuff since then so it’ll be interesting to see what they look like once they’re done.
We’re just having a celebratory (pottery) glass of wine out of one them now.
