Where can you get milages from. Ive racked up a nie amount so far this year, and imthinking I might record it?
Chain is 2 yards longer than a standard track panel of 60ft28ish sleepers to a chain in plain line
Where is the mileage measured from as sheffield signal box is 158m 29ch for example
so would sheffield signal box be 158 and 1/4 miles from that point?
main interested lines are Doncaster - Sheffield - London, Sheffield - Lincoln, Doncaster - London
Tom
Am I correct in the Miles/Chains to how it would be roughly in miles?
Tom
Tom
If you're wondering why they're called chains, it's because surveyors used to actually use metal chains, with equal length links, and a tag every 10 links with the measurement on. I learnt how to use one at college - mostly out of historical interest - before we went on to the high-tec modern surveying equipment such as dumpy levels (ok, not that modern and high-tec), theodolites and total stations.
More info here: http://en.wikipedia.org/wiki/Gunter's_chain
The mileage used to be measured from the headquarters of the old Railway Company.
So in most cases, it would be London, but in the case of the old North-Eastern Railway lines, it would be York.
Tom
New build Railways today are still built along similar methods !I think I am right in saying that the entire USA-Canada border (excluding Alaska) was marked out by men walking around with chains and sticks. Its about 2000 miles when you take away the great lakes. That must have been a fun job.
Tom
Of note is that the GBTT used to give the mileages against the first table for each line but this only covered passenger lines.
"Chainage"....
