Freightmaster
- Joined
- 7 Jul 2009
- Messages
- 3,498
Only ran for a couple of weeks before being abandoned as it wasn't viable!There is Immingham - Doncaster iPort for the short flows. Rather rare example though.
MARK
Water and Whiskey are quite different here!
If only! Perhaps in time.You won’t see any whiskey on trains in Scotland.
Whisky, perhaps.
Isn't that just down to lack of crew? There's still a weekly(?) Mossend to Aberdeen Waterloo path.I was incredibly disappointed to hear that the Aberdeen intermodal is now out of service, does anyone know why?
To be totally pedantic there may well be Bourbon and other American Whiskeys on containers coming to Scottish distribution centres from Southhampton etc.You won’t see any whiskey on trains in Scotland.
Whisky, perhaps.
The Aberdeen Waterloo traffic is calcium carbonate bound for Irvine and Workington.Isn't that just down to lack of crew? There's still a weekly(?) Mossend to Aberdeen Waterloo path.
No the traffic has been lost to rail altogether after a change of terminal operator/road haulier. It last ran in November 2021.Isn't that just down to lack of crew?
With straddle cranes or a reach stacker I'd expect moving the container not the wagon would be cheaper nearly every time, unless you were breaking a long train into >10 parts at a major yard.[I wonder if transloading a container from one train to another is more expensive or cheaper than shunting, if you had for example a proper location with straddle cranes vs an automated hump yard]
True, and the investment of deploying a portacabin and a couple of reach stackers to a site is buttons in the scheme of things, just as grabs are now quite frequently used for pop-up depots for aggregates/spoil.With straddle cranes or a reach stacker I'd expect moving the container not the wagon would be cheaper nearly every time, unless you were breaking a long train into >10 parts at a major yard.
It looks so simple when you put it like that. But ... ...True, and the investment of deploying a portacabin and a couple of reach stackers to a site is buttons in the scheme of things, just as grabs are now quite frequently used for pop-up depots for aggregates/spoil.
Where a siding already exists, it's even something that could be done on a trail basis with minimal capital risk. I'd say it could possibly be viable for less than one train a week.
BIB - Having a Reach stacker or two sat around at the yard not doing anything for a fortnight isn't a great use of the assets.True, and the investment of deploying a portacabin and a couple of reach stackers to a site is buttons in the scheme of things, just as grabs are now quite frequently used for pop-up depots for aggregates/spoil.
All agreed, but is this not all just standard logistics planning? Loading plans don't need to be made up at the actual siding; if a FOC doesn't know what wagons are in the consist then they are in the wrong business.It looks so simple when you put it like that. But ... ...
Containers are not just plonked down on the nearest empty bed, there various considerations, such as :
Container height v. wagon bed height (many trains are a mix of wagons of various vintages, heights, &c.).
Dangerous goods, both in the container and the train - have the separations been maintained?
Weight distribution on a given wagon.
Any of these may require boxes to be moved on the train, which blows away your time-saving very quickly.
Pat
PS I believe container handlers were going for about £½m a pop even when I was still working - some buttons!
Fair point, but it's still a much lower risk to deploy than a proper yard with cranes.BIB - Having a Reach stacker or two sat around at the yard not doing anything for a fortnight isn't a great use of the assets.
Wouldn't something like this normally need to be loaded onto a trailer to be moved around? So yes you could take it with you if the site doesn't work, but it's not like you're going to send it to a different yard every day of the week.And the point being about a reach handler, like a grab loader, is it's a mobile asset. So if it doesn't work out in a particular location you can move it somewhere else.
Well yes, but you wouldn't start putting in full gantry cranes unless you were dealing with serious levels of long-term traffic. Those setups take years to get agreements for and serious cash to install.Fair point, but it's still a much lower risk to deploy than a proper yard with cranes.
For small operations, a solution like this container lifter could apply.Wouldn't something like this normally need to be loaded onto a trailer to be moved around? So yes you could take it with you if the site doesn't work, but it's not like you're going to send it to a different yard every day of the week.
I don't think that @furnessvale meant the original piece of equipment as much as that a modern variant could be deployed.The Blatchford machine went the way of the Norwegian Blue many years ago.
Correct, I was thinking concept rather than the actual machine.I don't think that @furnessvale meant the original piece of equipment as much as that a modern variant could be deployed.
The military shunt containers in the field using simple telescopic forklifts, is there anything stopping the same being done in a small freight yard?Correct, I was thinking concept rather than the actual machine.
Again, with containerlift, we are talking lightly used sites and the ability to quickly move the crane to another location, which role containerlift can fulfill.
I don't think they shunt 20 or 40ft containers with a forklift. Happy to be corrected though.The military shunt containers in the field using simple telescopic forklifts, is there anything stopping the same being done in a small freight yard?
I'd argue it probably matters more, as you have less opportunities to male profit and therefore need to be as productive as possible for each train.It's a bit limited in productivity, but for a smaller operation with less frequent services, that perhaps wouldn't matter so much.
And then we get into the economics of having a spare wagon, having a forklift driver, and the time and space needed to load it up and then unload at each yard.These machines are often road legal too, albeit a bit slow to self deploy any distance. The other possibility is to put the machine onto a special wagon on the train itself, as is done with trailers in Europe etc.
The size of forklift to handle a loaded 45ft container is beyond road legal.The military shunt containers in the field using simple telescopic forklifts, is there anything stopping the same being done in a small freight yard?
Years ago I did some costings and timings on loading containers onto wagons at low throughput sidings versus directly loading conventional wagons using pallets.I don't think its going to be possible to escape the need for significant capital investment for freight yards
Either you end up with non-road legal loading equipment or fixed-infrastructure (straddle cranes or stands for Lohr UIC wagons or whatever) stuck at these sites long term.
Indeed the lowest capital cost solution is probably just use soft-sided (or side-opening) containers/swap bodies and load them from a siding with forklifts whilst they are already on wagons - but that raises all sorts of other cost problems. The demmurage on the wagons will be ruinously expensive, as will all the shunting operations required to get them in and out of the siding.
Using a forklift and pallets can be surprisingly effective, especially if, as you suggest, the loading is to a curtain side swap body for lifting at the other end at a larger throughput depot.
Whether such traffics can be identified I leave to others.
