His Majesty The King: Royal Train
Taunton
1 Aug 2013
I believe it's been talked about but there is a security concern about the train being stranded. DB Cargo run the train, and they're not in line to get any bi-modes yet so we shall have to wait a while. Even so, a Class 67 fully under the wires is probably better environmentally than a Helicopter flight.
Of course, the first ever Royal Train hauled by a brand-new diesel, in 1960, which had been inspected and admired before departure from Liverpool Street for Sandringham, broke down at Audley End when the lubricating oil pump failed.
Unfortunately we no longer have grimy B1s as Cambridge station pilot, which was instantly dispatched at supersonic speed to assist ...
Western Sunset
23 Dec 2014
Wimborne, Dorset
Am I correct in thinking that only (the former) Queen's Saloon had special doors at one end where HM could easily step from the carriage onto the red carpet?
43096
23 Nov 2015
I think the scrambling is more to do with the freight obfuscation - AIUI the headcode isn't meant to be publicly visible at all.
Freight train reporting IDs are no longer scrambled.
Bristol
There is certainly a saloon with double doors to provide a more ceremonial arrival.
(image from https://image.cnbcfm.com/api/v1/ima...2106226.jpg?v=1529517588&w=929&h=523&vtcrop=y)
One interesting possibility for replacement is as a Bi-mode MU.
popeter45
7 Dec 2019
london
was about to say, a micro order of class 80X combined with maybe a goverment train or two would be intresting,a portable SCIF for ministers would be useful
thou if for said goverment train you wanted to also use it for travel on the continent carriage would prob make more sence as no need to try fit every possible power/signal combination into a cab
The Puddock
10 Jan 2023
Frog
You're right that 2903 (The Queen's Saloon) has double doors but it's not the only vehicle in the fleet with them - 2922 (the Prince of Wales' Sleeping Car) also has double doors at one end.
The Japanese Imperial family has a dedicated six car Hitachi E655 EMU operated by JR East. It can also be chartered privately (at eye-watering cost) so the Imperial saloon is only inserted on Royal workings. The unit is dual voltage and can also be loco-hauled when necessary.
Magdalia
1 Jan 2022
The Fens
The Royal Train loco failure was on 11 January 1961 but it was not the first ever diesel hauled Royal Train. HM Queen Elizabeth II was travelling back to Sandringham on the down Fenman, after a day trip to London, and had also been diesel hauled on the up Fenman earlier in the day. Another trip up to London and back the previous week was also diesel hauled. Princess Margaret was diesel hauled on her way back from being awarded an honorary degree at Cambridge on 6 November 1958, and this is thought to be the first diesel hauled Royal Train on British Railways. In these instances ECJS saloons were attached to service trains.
Peter Mugridge
8 Apr 2010
Epsom
I understand the royal trains movements generally aren’t publicised for security reasons
True, but it's worth reading the Palace press releases... they do sometimes say in advance things like "H.M. will arrive at ( name ) station and be greeted by ( local dignitary ) blah blah blah" which would be enough to indicate it's running and often the arrival time as well - although not the exact route.
43066
24 Nov 2019
I’ve yet to encounter it “in the wild”.
As an aside, one of the “royal” 67s was at London Victoria the other day, on a special to Bath Spa. It’s certainly an impressive livery.
rower40
1 Jan 2008
I’m sure someone with more info will come along in a minute…
On the Bodmin Road to Bodmin General line, there is a location known as “Charlie’s Gate”. The Royal Train was parked there overnight at least once to allow the then Duke of Cornwall to sleep before a bruising schedule of walkabouts and handshaking throughout the Duchy.
fgwrich
15 Apr 2009
Hampshire
Some of us have been lucky to work with it (though sadly not on it!) - I've even touched it and kept all my fingers :lol:
It's an impressive livery when kept clean - thankfully they seem to have stopped using the Royal 67s on jobs like the RHTT / Sandite, though they are often utilised on Railtours and the VSOE in-between their Royal Duties.
dk1
2 Oct 2009
East Anglia
Wonder if she (and accompanying entourage) were issued with tickets for that, likely with 100% discount?
They were & it was well publicised in the local news & media that the Queens ticket was purchased with her senior railcard discount. Not quite sure why the press were always so hung up on that fact.
The Puddock
10 Jan 2023
Frog
I've worked with it many, many times over my career. I've never travelled on it but did once get a look round on board while it was stabled - though bits of the Principal's vehicles were out of bounds for obvious reasons. One thing that some might find surprising is that the staff are charged for all the food they consume on board during a trip!
Bristol
Thanks.
I’m guessing that one way to work out if it’s working is to keep an eye on light engine movements from Toton to Wolverton?
You'll have to keep a good eye out - the schedules aren't meant to show in TRUST and therefore shouldn't pop up in RTT, and the stock can often move the day before to an alternative stabling location for a number of reasons.
50002Superb
18 Aug 2021
Understood.
I have always wanted to see it in the flesh but just not savvy enough to work out how / where / when
The Puddock
10 Jan 2023
Frog
The light engine move schedules are suppressed in TRUST, yes.
In my experience that is very unusual. It normally runs empty straight from Wolverton to whichever terminus is being used for the departure of the trip (usually Euston, Victoria or Windsor & Eton Riverside, depending on where it's heading).
Does it have a TSC incase
Yes, it's 21994001. But again you won't find it on any industry systems because the schedules are suppressed.
Bristol
Unusual, but does happen. I saw it quite by chance in waiting in Wembley Yard one time on a Saturday night.
Slightly defeats the point to be posting it, but then it's listed on rail-record.co.uk so I guess the cat's out of the bag on that one.
The Puddock
10 Jan 2023
Frog
It's not a secret. As said, searching on industry systems or rail enthusiast sites won't find anything because there's nothing to find. The TSC exists to allow the trips to be correctly paid for.
urbophile
26 Nov 2015
As a republican (small r) I see no reason why the royals shouldn't use scheduled services. But as a fan of exotic and unusual trains I'd like to see the 'royal train' continue in use. Maybe the Prime Minister will also take the hint. Even if he insisted on his own train it would be better for the environment than a helicopter.
DarloRich
Fenny Stratford
That's great. Many Britons and foreigners alike, including young children, would enjoy watching the Royal Train go by, so although it might cost a fair bit to operate, it has a 'value' beyond where the King, Queen and others may be visiting.
It has bot all value for us as tax players and most people wouldn't give a stuff it it rolled past them.
Personally, I would rather they used the train more than helicopters and planes but accept the later are more practical on many occasions. The trains is, of course, met by the usual Royal motorcade and security people and road closures and post boxes sealed up etc
The only issues the Royal train have ever caused me are making my chow main cold as an armed policeman stopped me using my usual street past a station - where the RT was stabled overnight. i think the DoE was on baord at the time ( there was also a story some burglars got a more serious reception then they expected from PC Plod when they unknowingly ran into the RT security cordon after a job!)
The security arrangements surrounding the distribution of the schedules are, in theory, quite strict.
Not in theory - in reality.
I know someone who was given a roasting for asking a few banal questions about movements. I heard from another source he had a visit form the local constabulary but have never had this confirmed.
Prior to becoming King, Charles has made a point of shaking peoples' hands when walking along streets for a 'meet and greet', so a different appropach to the late Queen, but good.
The Queen did walkabouts until she became a very elderly lady. Women of the age of the Queen don't shake hands with randoms!
The late Queen would occasionally use a service train to King's Lynn when travelling to Sandringham, I believe with the coach locked out and a fair number of heavies around.
My mum insists she was on a train to Kings Lynn used by the Queen ( I think it was another Royal like the Duchess of Kent of some such) where they set aside the first class area behind the cab for "VIP use" guarded by a couple of obvious security men.
I once saw David Cameron when PM get off a service train at Bedford. First class. ( typical tory) with only 2 obvious security men. Assume there were others there who less conspicuous but the 2 he was with were straight out of central casting!
The look he gave me when I booed him could have curdled milk!
IIRC the train is largely formed of modified prototype HST Mk3 vehicles, and will be needing a refresh or replacement at some point not too far down the line.
They will need a replacement ( personally I suspect removal) at some point but the RT vehicles are low mileage and superbly maintained.
Living in MK we see it quite often. Think i have only ever seen it ECS
Milton Keynes Central by MK Darlo, on Flickr
Do they still store the stock at Wolverton when not in use?
Yes - although the original royal train sheds are now houses
Bristol
I used to work the summer festival at Glyndebourne as an Usher, and some of the security men were more obvious than most. One of my colleagues had a good story about how somebody had come up to her entrance, had a good look around and then turned around so she asked him 'who are you guarding then' and he'd just sunk a bit and asked sheepishly 'is it that obvious then?'. (It was a lesser royal, I think).
Mikey C
11 Feb 2013
Off topic, but surely it's entirely correct that the Prime Minister, of whatever party, travels first class.
Shaw S Hunter
21 Apr 2016
Over The Hill
Also Charles's green credentials have sometimes come second to his love of British engineering, and the train has been hauled by a few Steam Locos over the years (IIRC Charles has been on the footplate of Tornado for at least one run).
I once saw him alight from the footplate of Tornado at Manchester Victoria. He immediately boarded the train itself in order to remove his overalls before being officially greeted by the assembled dignitaries. I've heard it suggested that he's been known to take a brief turn with the shovel! The security on the station was quite thorough with a number of not quite incognito, and doubtless armed, officers patrolling the platforms and just prior to the arrival they closed off the eastern end of the station disrupting a few traincrew mealbreaks in the process.
In the early 1980s HM The Queen paid a visit to the north-west. She had an official engagement in Manchester one morning having been in Liverpool the day before. I assumed she would use the Royal Train from Liverpool and duly positioned myself on the car-park on the former platforms of Exchange station to see her arrival (and attracted the attention of an alert patrolling Constable - brief chat and check of my bag and all was good) In fact she had spent the night on board the train stabled in the sidings at Castleton Junction so I had to wait for the ecs to leave to get a proper look.
The curve between Parkside and Lowton Junctions has alongside it (eastern side) some very sturdy looking brick-built bothys: I was once told these were for the use of security details on occasions when the Royal Train stabled there overnight. There are doubtless similar situations elesewhere.
43066
24 Nov 2019
Thanks - great pics!
I think @DarloRich has something of a bee in his bonnet about first class :). Putting egalitarian concerns to one side, they generally end up cordoning off a coach or part of one for security reasons, and first lends itself better to this.
trebor79
8 Mar 2018
Saw it about 30 years ago when it passed our house on the Leamside Branch. We were amused to see several very smartly attired stewards leaning out of the windows of the rear coach, having a crafty fag :lol:
