Class15
I see, could bi-modes be a solution?Tfw have lots of aspirations regarding the Welsh railways, it's all very ambitious and it will be interesting seeing what is achievable over what is just an aspiration.
Some of these I can believe are difficulties, but the Britannia bridge is unlikely to be a particular problem. The road deck above the railway will undoubtedly have been designed with electrification clearance.Electrification to Holyhead would be very difficult.
The Crewe - Chester line has numerous very low bridges. Too many for an interrupted electrification scheme to work, they'd need demolishing. It also has the very tight Christleton Tunnel - which can't raised because there's a canal over it, and can't be lowered because it's prone enough to flooding as it is.
As you go down the coast, it doesn't get much better. Lots more tunnels, the Brittania Bridge, the railway wrapping around the walls of Conwy Castle, and probably the biggest hurdle of all - the Conwy railway bridge. Putting wires or a bar through a Grade 1 listed wrought iron tube is going to make for an interesting challenge.
I'm sure none of these problems are insurmountable by any means - but they'll be very expensive. And what do you get in return? Avanti have been very slow to return their North Wales services to normal post Covid, showing how low it is on their list of priorities. TfW are keen in increase their services on the route - but almost all of them continue on to other routes that are also unlikely to be electrified.
The cost:benefits ratio for this are going to be ridiculous. It's not the low hanging fruit for electrification some make it out to be.
The Welsh Government did not fund London-Cardiff electrification or the IEP train fleet.
The Valleys electrification (and Metro project) is being funded with a £250m grant from Westminster to Cardiff Bay.
Like I said, I figure they're all doable, just it might take some creative bespoke solutions that won't come cheap. I agree with you the height on the Brittania Bridge is almost certainly sufficient, but it's still a fairly unique structure, suspended at great height over water. A smaller problem than the issues at Conwy but surely not as straightforward as open track in the country?Some of these I can believe are difficulties, but the Britannia bridge is unlikely to be a particular problem. The road deck above the railway will undoubtedly have been designed with electrification clearance.
As for the Conwy tubular bridge, is there a published cross section with dimensions? Without seeing one I'll keep an open mind.
Conwy castle will raise heritage issues which will require sensitivity in design and public relations, but not necessarily great expense.
They somehow managed to leave Acton Wells unelectrified.
Ah, sorry, I meant Acton Bank. I think that the Felixstowe to Wentloog liners could then be electric from Ipswich, if the curve was electrified.Acton Wells has been electrified for over a century!
If you mean Acton Bank, then have a look to see how many trains that use it run entirely on lines that are electrified other than that stretch.
I never said the £250m was the sole Valleys funding, but it is a big chunk of the project.If that's your view, then the Welsh Gov funds nothing at all as basically all of the money comes from somewhere else.
The Core Valleys project budget is about £750 million so there's a huge hole if you think £250 million from the UK Government is funding it.
In fact, it has multiple funding sources including £160 million from the EU.
Well, the Valleys will undoubtedly be a litmus test for discontinuous electrification - agreed the bridges will need to go, but a battery section through Christleton Tunnel shouldn't be discounted just yet IMO.Electrification to Holyhead would be very difficult.
According to this site, The tubes are 4.4m wide, and 6.9m high at the ends rising to 7.8m. So if the structure takes up a metre at the top and bottom, then that still leaves 4.9m for the trains and any wires. So should be ok, but does entirely depend on how the structures actually work, they may have cross-braces etc which go into the space. I did find a driver's view video, but it's completely black through there!Some of these I can believe are difficulties, but the Britannia bridge is unlikely to be a particular problem. The road deck above the railway will undoubtedly have been designed with electrification clearance.
4.9m for the trains and any wires? Looks like it'll have to be contenary through there without a doubt.According to this site, The tubes are 4.4m wide, and 6.9m high at the ends rising to 7.8m. So if the structure takes up a metre at the top and bottom, then that still leaves 4.9m for the trains and any wires. So should be ok, but does entirely depend on how the structures actually work, they may have cross-braces etc which go into the space. I did find a driver's view video, but it's completely black through there!
The twin bore Carmuirs tunnels in Scotland - which also have a canal over them - were rebuilt and raised for the Greenhill-Stirling- Dunblane-Alloa-Grahamston-Polmont electrification.Christleton Tunnel - which can't raised because there's a canal over it,
Wonderful how they managed to make the water go uphill.The twin bore Carmuirs tunnels in Scotland - which also have a canal over them - were rebuilt and raised for the Greenhill-Stirling- Dunblane-Alloa-Grahamston-Polmont electrification.
How about having the power via a rail alongside the track rather than overhead?Like I said, I figure they're all doable, just it might take some creative bespoke solutions that won't come cheap. I agree with you the height on the Brittania Bridge is almost certainly sufficient, but it's still a fairly unique structure, suspended at great height over water. A smaller problem than the issues at Conwy but surely not as straightforward as open track in the country?
building third rail completely unconnected to the existing third rail systems in the UK? I'm not sure that would make sense (or get approved by the relevant safety people!)How about having the power via a rail alongside the track rather than overhead?
There is a drawing of the Britannia (Menai Straits) bridge in this Network Rail video which shows the internal dimension of the tubes (3m19s) as 22 feet (6.7m) high. I would presume the Conwy bridge tubes are the same. The track bed will reduce this clearance.As for the Conwy tubular bridge, is there a published cross section with dimensions? Without seeing one I'll keep an open mind.
Those tubes were destroyed by fire in 1970! The present obstacle to clearance will be the height of the road deck, although this would provide a surface to attach a wire to.There is a drawing of the Britannia (Menai Straits) bridge in this Network Rail video which shows the internal dimension of the tubes (3m19s) as 22 feet (6.7m) high. I would presume the Conwy bridge tubes are the same. The track bed will reduce this clearance.
His point was that the tubes of Conwy bridge may be the same dimensions. As I remarked in #34, the road deck of the Britannia bridge will have been designed with electrification clearance.Those tubes were destroyed by fire in 1970! The present obstacle to clearance will be the height of the road deck, although this would provide a surface to attach a wire to.
You say undoubtedly but I hope your confidence is justified. Obviously Victorian structures weren’t designed for electrification clearance though. If Chester - Holyhead is electrified but the Marches aren’t, will TfW’s Premier Mk4 service have to do a loco change at Chester? I wonder what electric loco would be suitable for hauling Mk4 coaches…His point was that the tubes of Conwy bridge may be the same dimensions. As I remarked in #34, the road deck of the Britannia bridge will have been designed with electrification clearance.
But it would be an extension to the existing third rail system, allowing fully electric through services on the busy Liverpool to Holyhead corridor...building third rail completely unconnected to the existing third rail systems in the UK? I'm not sure that would make sense (or get approved by the relevant safety people!)
I took a photo looking along the railway line across the bridge in 2014. Counting stone blocks, the minimum 5.03m road clearance on the road gives about 5.75m above the railhead (10 blocks on road vs ~11.5 on rail).[....] As I remarked in #34, the road deck of the Britannia bridge will have been designed with electrification clearance.
North Wales is surprisingly well endowed with 400kV power lines.The mention of Wylfa nuclear further up the thread sparks the impression of two 25kv cables bringing the power to where it’s needed in north west England!
