Holyhead Port Closure Until January 15
Blindtraveler
28 Feb 2011
In which case I suspect it's a case of one side or the other or indeed both can't. For whatever reason, resource additional capacity to do another load on and load off for a Dublin sailing, especially given that these Dublin sailings are going to have to slot onto the existing link span in between the two scheduled passenger Belfast's and the freight sailing, plus the Dublin freight service
3 Mar 2013
You'd think they could even bring the buses over from Holyhead. Assuming they are Road legal of course, they may well not be if only operating within the confines of the secure area of the port.
Flying Snail
12 Dec 2006
There are 2 linkspans at Birkenhead, the freighters use the single deck while Stena Estrid has easily slotted in between the Belfast sailings on the main double deck span. There is another slot available between 11pm and 6am.
The main capacity constraint at Birkenhead is the lack of space for freight and cars at the port, they were struggling already with just the Belfast traffic.
I have no reason to doubt that Immigration/customs is the problem stopping foot passengers from Dublin, the attitude towards foot passengers (and scheduled coach passengers) at UK ports is very different to motorists.
If as is being suggested that Holyhead is likely to be out of action for months then some better arrangements need to be made by all concerned.
kevconnor
22 Apr 2013
People's Republic of Mancunia
In normal times, part of the problem is that the Stena Birkenhead - Dublin service users terminal 5 at Dublin, which is shared with CLdN services. Terminal 5 has no facilities for foot passengers. This is not a problem currently as there is spare capacity at terminal 2, but it is impossible when things return to normal.
philthetube
5 Jan 2016
I wonder if the Ben-My-Chree and Mannanan will be swapped over after the new year, the Ben could probably cope with capacity to the Isle of Man so the result would be extra capacity for Stena and more money for the Steam packet company
Flying Snail
12 Dec 2006
Mannanan is their fastcraft, I assume you mean Manxman.
Manxman does not have a higher freight capacity and is no faster (Ben has struggled to do Heysham and return in a day) so swapping them not be of much use.
January to March is normally the refit season for the Irish sea fleets as it is by far the quietest period and has in recent years seen temporary dropping of service on Rosslare routes, that is not likely to be acceptable this year as long as Holyhead is out of action but refits will still be necessary for some ships.
If they really wanted to take foot passengers it would be a trivial matter to do so, using T2 for check-in and bussing to the ship from there would probably be the simplest.
So far they have leased a single unaccompanied freight ship for the route so were not even taking truck drivers or cars.
kevconnor
22 Apr 2013
I have kept an eye on this hoping they may allow cars as Sea Truck Ferries did. Currently, the Stena Freight booking system allows accompanied freight from the size of a van upwards to be booked for Liverpool - Dublin.
Cloud Strife
25 Feb 2014
Honestly, they should sort out Dublin Port as a whole. The current experience is just a mess, there really should just be a single terminal building for foot passengers regardless of which terminal they actually use. The entire area used for Stena / Irish Ferries / CLdN / IoMSP is a complete mess and a lousy experience for passengers.
About Holyhead: I've heard anecdotally that T3 may already have been somewhat damaged before this latest incident. My contact alleges that IF have been quite reckless with the infrastructure for years, and that there were several incidents where sailings had to be moved to T5 as a result of hard hits to the T3 side of the jetty.
chiltern trev
28 Mar 2011
near Carlisle
Manxman is a larger ship than Ben My Chree so I assume it can carry more freight. Biut Manxman cannot do Dublin certainly in passenger mode due to it having a new evacuation system which Ireland does not like. Plus you would have loads of complaints from the Manx residents!
philthetube
5 Jan 2016
Suspect the Manx Government would be rubbing their hands if it meant less subsidy.
Sorry yes
poffle
11 Oct 2023
Dublin, Ireland
There seems to have been a statement from Stena today saying that they now expect to resume services from T5 by 16/Jan unless bad weather delays work.
Part of the Holyhead ferry port is on course to reopen on 16 January, after damage caused by Storm Darragh meant it was forced to close over the Christmas period.
Ferry company Stena Line, which owns the port in Anglesey, north Wales, confirmed it would reopen the Terminal 5 berth subject to reasonable weather conditions.
It is yet to provide a timeline for the reopening of Terminal 3.
A statement said: "After diligent assessments and planning, we can now confirm that the timeline for reopening the Holyhead Terminal 5 ferry berth by 16 January 2025 remains achievable.
"This prediction is subject to reasonable weather conditions, and we will provide further updates as our progress continues."
All ferry services between Dublin and Holyhead have been cancelled over recent weeks, affecting thousands of people travelling to and from Ireland over the festive period.
Stena Line said that when Storm Darragh hit on the weekend of 6 December, there were two incidents at the berth at Terminal 3.
It said that this resulted in part of the structure collapsing and rendering it unusable.
Damage was feared to have been much worse than initially thought and a spokesman for the port said it had been necessary to perform underwater inspections of the structural integrity of the adjacent Terminal 3 and Terminal 5 berths.
On the latest announcement, Stena Line added: "Up until the reopening of the Terminal 5 berth, alternative routes for travel include Birkenhead to Dublin (motorists only), Fishguard to Dublin, Fishguard to Rosslare, Cairnryan to Belfast and Liverpool to Belfast."
A spokesman for Irish Ferries said: "With clarity now on the situation for the coming weeks, Irish Ferries will continue to review what further route measures are required to ensure the needs of its passenger and freight customers are met.
"With a phased reopening plan of Holyhead port that involves more limited berth availability, Irish Ferries has agreed a timetable with the other operator that will allow Irish Ferries to operate full schedules into Terminal 5."
poffle
11 Oct 2023
Dublin, Ireland
Statement in the Senedd by the Cabinet Secretary for Transport and North Wales, Ken Skates on 7th January.
It's quite long and wordy and obviously the Senedd has been off for most of the time since this started so there is a bit of catching up.
Key thing he says is that Holyhead still expects to reopen on 16th January with 4 sailings per day to Dublin. ( This would correspond to the normal Stena sailings alone. Irish Ferries would also have had four sailings per day.)
There is also talk of establishing a Welsh Government-led multistakeholder taskforce to develop a new strategy for the future of Holyhead, he says he hopes to bring in Irish and UK governments along with other stakeholders.
Blindtraveler
28 Feb 2011
Positive to hear that at least some level of service will be provided from North Wales as of the tail end of next week, can't imagine Irish fairies are too happy about the continued disruption however, but well done to everyone who's made at least this level of service possible. It will hopefully relieve the pressure a little on some of the other routes that are perhaps more easy to access for foot passengers such as birkenhead, and the service I use most regularly when going across the pond
berneyarms
26 Nov 2013
Dublin
Not sure if someone has got their wires crossed?
Irish Ferries are selling four round sailings a day from 16th January with both ferry companies adjusting their schedules accordingly to use the single jetty.
poffle
11 Oct 2023
Dublin, Ireland
Irish Ferries have published a timetable that they intend to operate on the Dublin - Holyhead route from 16/1/25 until 28/2/25.
Departures from Holyhead at 01:30, 07:30, 13:15 and 19:30.
Departures from Dublin at 01:15, 07:30, 13:45 and 19:45.
I presume that for some/all of these the ferry will dock at Holyhead, unload, undock and then subsequently redock, load and depart as there are quite long intervals between arriving in Holyhead and departing for the next sailing.
I think this breaks the Sailrail connection on the 09:00 Avanti service from Euston.
I can't see any info on Stena about what timetable they propose to operate.
berneyarms
26 Nov 2013
Dublin
As I posted above, Stena have changed their times too - timings can be seen in their booking engine.
Ex Holyhead: 04:00 (Tu-Sa); 10:00; 16:00; 22:15
Ex Dublin: 04:30 (Tu-Sa); 10:15; 16:30; 22:30
There won’t be any undocking and redocking (except on Sundays and Mondays when Stena drop sailings) - each ferry will arrive, unload, reload, and depart again. The timetable has been constructed to facilitate both companies.
The Sail/Rail connection out of the 09:00 ex-Euston is indeed broken for Irish Ferries. Let’s be honest, that’s really not the most important factor here - it’s getting the freight back on track.
I don't know about Stena, but half of the Irish Ferries departures do not operate on some dates because of ship maintenance.
The MAIB have said there are no further investigations needed.
There's apparently a video of the jetty collapse on the Daily Post site, but I haven't been able to get it to load.
Marine Accident Investigation Branch - a UK Government organisation authorised to investigate all maritime accidents in UK waters - started making enquiries to "better understand the circumstances which may have contributed to the incident".
They have now released a new statement to North Wales Live. They said: "The MAIB has completed its preliminary enquiries into the maritime aspects of the incident at Holyhead. The information gathered does not indicate any significant safety issues that would necessitate further investigation at this time."
43055
8 Mar 2018
Reports elsewhere that Irish Ferries 'James Joyce' is leaving the fleet shortly.
berneyarms
26 Nov 2013
Dublin
Yes it would appear that Irish Ferries are operating:
Dublin/Holyhead - 07:30 & 19:45
Holyhead/Dublin - 01:30 & 13:15
The second set of sailings are not available to book.
poffle
11 Oct 2023
Dublin, Ireland
Irish Ferries Ulysses is in dry dock on the Tyne for annual overhaul.
berneyarms
26 Nov 2013
Dublin
I know that.
But it’s back at the end of the month and the WB Yeats will cover those two return sailings in the meantime.
I’ve checked the booking engine for the entire month of February and the other pair of return sailings that are listed in your post #47 are greyed out in the booking engine and are unavailable to book (shown as operated by Isle of Inisheer).
poffle
11 Oct 2023
Dublin, Ireland
Historically the "second" Irish Ferries vessel on the Dublin - Holyhead route operated as a freight only vessel.
In recent times they've had Ulysses and James Joyce on the route so I think they were taking cars and maybe foot passengers. They weren't offering Sail Rail.
I think it was normal during refit periods to operate the "second" service as freight only. I think they're keeping their options open.
After 28/2 they're showing the Ulysses as their only ferry operating Dublin - Holyhead. I'd expect something will appear but they obviously aren't committing themselves at this stage.
Blindtraveler
28 Feb 2011
Possibly the wrong place to ask, but are there now any Rail and sale options from London via North Wales in the current temporary timetable starting at the end of the week? Cheers
berneyarms
26 Nov 2013
Dublin
Yes, but the times are now different, and they may require longer waits and/or more connections.
Flying Snail
12 Dec 2006
Sailrail tickets seem to be available for both ferry companies but the Rail ticket system is still quoting the normal times which will not be correct for connections. Using the quoted connections towards Dublin you would miss the Irish Ferries sailings and be unnecessarily early for the Stena Line sailings. I'd suggest buy the Sailrail Standby ticket and work out your own connections.
Flying Snail
12 Dec 2006
Cheers. Any idea which online booking system does the standby ones or are they only available from a booking office? I'm not fussed either way
Anywhere that offers one should also offer the other.
The name "standby" is a misnomer, they are more like an Anytime with slightly more restrictions, that being no Break of journey.
