Killingworth
I thought that the various 'Southern' tunnels worked on a 'flying through' basis. I.e. that a train cannot be signalled into the tunnel unless the signal beyond the tunnels is showing a green aspect (so any train in the tunnel is very unlikely to slow or stop in or just beyond it).
The problem with Totley is that there are all sorts of reasons why trains will regularly stop just beyond the tunnel.
Westbound isn't such a problem. Coming east there's a double bottleneck just beyond the tunnel.
The single track section from Dore West to Dore Station Junction through Dore and Totley Station is the one most passengers will note. There have been plans to redouble there for probably 30 years. A late running passenger service (a very frequent event) released into the tunnel at Grindleford will want to go as fast as permitted and it's downhill from not far in. But Dore West Junction will often bring it to a stand. Count down boards warn of the need to be ready to stop to allow a service going the other way and it's an important warning.
It's often not a passenger service but an empty freight that might also be coming round from the northbound MML. That's assuming a preceeding loaded freight has been able to get round the Dore curve!
The two elements of the scheme at Dore should greatly benefit eastbound services, especially combined with the Bamford loop. Westbound is less of a problem as freight trains are normally empties and much lighter. I suspect more cement trains will be routed round the Dore curve than at present as they'll be able to stand on the new loop to wait for a Hope Valley path
