Having recently travelled between Liskeard and Looe on a 2 car class 150 which had standing room only, made me think is there any cost effective way in which additional capacity could be created. With the short platform at Looe, unless selective door opening was to be used which would not be ideal on a branch terminus where most passengers are travelling end to end there is little that can be done as much of the day the service already runs with tight turnarounds at each end.
Could the branch run with 2 units and pass at Coombe with one unit waiting in the platform while the other reverses at the ground frame? This would still probably only allow for a service approx every 45 minutes as the Looe side of Coombe Ground Frame is about twice the distance and time of the Liskeard side. Perhaps if combined with an increase in speed on some sections (what is it about this line that it has such a low maximum speed?) you could end up with 3 trains per 2 hours.
Perhaps an easier solution would be to use rolling stock with 3+2 seating, but the 150/1 units GWR used to have with this configuration have all now left the franchise. I am not even sure if they were route cleared for this line as I have only seen single class 153's and class 150/2 units on this line?
