RichmondCommu
The fact that four GWR trailers are at Wabtec for conversion, plus 43194 there as well (to have the interlock mods done), is a bit of a giveaway, is it not?
Well it is now you've told me.
Surely Wabtec at Doncaster are already working on the first coaches, unless I've been misinformed.
Separate but slightly related question. I used to have to catch the Leicester to Stanstead train. But it was often just two carriages and crowded - obviously going to an airport.
I asked a member of staff why they didnt put one or two extra carriages in the middle of the train (it had a drivers bit at both ends). He said it wasn't possible because they were made like that.
Is that true ?
You're correct that there's little rolling resistance, but the carriages still have mass and hence inertia. It takes energy* to get them moving and a Turbostar doesn't really have much going spare.Or have I got that terribly wrong..............??
BUT... I thought one of the many advantages of train was that metal wheels on metal track means very little rolling resistance. Hence shoving a couple of extra (unpowered) carriages in the middle of a two carriage Turbostar shouldn't make much difference to the performance.
like a hamster pushing a filing cabinet.
Ah.... I see. Many thanks to all.
Separate separate question. Why don't they produce units that can be easily made into longer or shorter trains but which are cheaper to manufacture. Perhaps even a Turbostar with a bigger engine??
Thanks agaain. I find this topic interesting.
Because it is easier, cheaper and faster to couple entire sets - e.g. two threes making a six - than it is to go through the process of uncoupling the end carriages, driving them off somewhere else to wait, attaching intermediate carriages and the bringing the end carriage back and reattaching it.Separate separate question. Why don't they produce units that can be easily made into longer or shorter trains but which are cheaper to manufacture. Perhaps even a Turbostar with a bigger engine??
That was done a generation ago. They were called the "Modernisation Plan" units. Thousands of cars were produced, they were affordable, there were sufficient for strengthening services where required, and they lasted 30 or more years.Separate separate question. Why don't they produce units that can be easily made into longer or shorter trains but which are cheaper to manufacture.
Well, it's not false.You couldn't make it up. So I didn't. It's true.
However, it was determined to replace them with a fraction of the number of cars, much higher priced, with harder and more squashed-up seating (for the few lucky enough to get a seat), while well-paid technical designers came up with different coupling connections that meant that even trains which looked otherwise identical couldn't be coupled together. You couldn't make it up. So I didn't. It's true.
Is that true ?
To be fair, we often see many interesting combinations of pacers, sprinters and super-sprinters, so compatibility was being done with the later BR DMU's.
Yes.
They could have been built as 3car units, but that would have cost c.50% more.
Or as 4car units, but that would be c.100% more expensive.
The days when you could just stick an extra coach or two onto a train are long gone.
Ahh but try and couple them to 165s or 166s
Never seemed to do me and my colleagues any harm.
sub question. Do trains at St P get refuelled in the station and have their toilets emptied? And how long does that take?
Which never stopped the transcontinental lines in USA and Canada having refuelling (and watering for the steam heating) points for the locomotives at the front end of key station platform.re refeulling: Think of the risks involved mixing unwary passengers with refuelling equipment, problems with spillage, etc Far better to keep the two operations of loading/unloading and refuelling (and anything but minimal maintenance) separate.
A cost analysis I saw showed that the driving cab and its connections and fittings can be 15-20% of the vehicle cost. Trailer = no cab.They could have been built as 3car units, but that would have cost c.50% more.
As far as is known, yes, it was simply NSE putting a barrier in the way of Regional Railways.
Of course, NSE managed to nab what became the 159s off RR (roughly)- if everything had gone to plan for both divisions it would have been Networkers for the South West too.
One of my pals, who worked in a PW gang for a few months (back-breaking work, he said, took him a month to get used to it) told me the gang would always turn their backs to passing trains, angled slightly in the direction of travel, to avoid any sh*t hitting them in the face.
If the engines on the cab cars are specified sufficiently powerful to handle a trailer as well, that is a very substantial reduction in cost and weight.
