Split from this thread, how would you use electric trains on this section which both Chiltern and London Underground run on?
You can have 4th rail and OHLE on the same track which won't require dual voltage trains
Difficult but not impossible, it will depend on how they view the use of dual voltage or bimodes. I believe this section is 750v (it got upped from 630v as part of the 4 lines modernisation) so they should be able to use fairly standard dual voltage EMUs.Indeed. Hence why I said dual-voltage stock was "easier", rather than the only way.
Dual-electrification of the line is difficult, and NR's West Midlands & Chilterns Route Study's Technical Appendices has the following on the matter (my bold):
To maximise the benefits of the Chiltern capacity and connectivity package, analysis has considered potential electrification options for the line between Aylesbury and Marylebone (via Amersham) which does not form part of the main line scope. The line includes infrastructure between Amersham and Harrow on the Hill that is owned by London Underground Limited (LUL) but shared operationally with Chiltern Railways (highlighted in red in Figure 4.7). Electrification options have been identified for this line, taking into account the DC 4th rail electrification on the section between Amersham and Harrow-on-the-Hill. As it would be challenging to operate and maintain an OLE (AC electrification) system alongside the 4th rail section, the introduction of AC electrification on part of the route (excluding the section between Amersham and Harrow on-the-Hill) has been identified as a potential option. It is proposed that this should be considered as part of any future development work assessing main line electrification. Key to this development work will be understanding the impact of different options on the future Chiltern rolling stock fleet. Progressing the option to part electrify (AC) the Aylesbury – Amersham – Marylebone route would require assessment of dual voltage or bi-mode rolling stock options which could operate as a combined fleet on both this route and the main line. The potential to use an independently powered EMU has also been considered, with initial modelling work supporting further development of this option.
