LucaZone
This is sparked by a graphic in what some like to call 'Liar' but bear with me, as I think its an interesting discussion.
Rails current issue (640) has a graphic of a proposed layout for an Old Oak Common interchange between GWML and HS2, positioned directly opposite the North Pole building.
Now, the interesting aspects for me are:
- The HS2 portion is ontop of the existing FGW HST sheds and sidings, completely avoiding the now empty ex-EWS area to the north.
- Didnt they just close the EWS part of OOC to make way 'possibly' for Crossrail?
- Is there anything stopping the HST depot moving to the North Pole site? Would that supply enough capacity
- Would it be an issue to transfer the HEx and Connect fleets to the other part of the North Pole site, the other side of the NNL bridge to the east?
- The GWML portion consists of platforms on all lines to and from Paddington.
- Is ANY ever going to stop on the fast lines, 2 miles outside Paddington? Surely there should be no platforms on the fast lines that close to Paddington.
- Platforms on the slow lines make sense, just like the moderate use of Acton Mainline a be further along.
- OK, so if someone coming from Reading way, wants HS2, they would have to go into Paddington and back out to change at OOC, but is that really a problem?
