My concern though is that the disabled maybe able to walk on the HS2 trains at HS2 built platforms, but at other stations, they would have to wait for train guard/station staff to be providing a ramp to get off the train. This should not be the case in the 21st Century and in such situations passengers have been forgotten. This is despite the article
https://www.rssb.co.uk/about-rssb/k...gap-with-lower-train-floors-and-sliding-steps that states that the size of the gap is important.
The proportion of new compared to classic platforms planned to be served by HS2 trains has also reduced somewhat recently!
The supplier limitation on lower floor trains was very real but a result of other requirements in the specs. HS2 insisted on distributed power; the shinkansen model with every car motored. The problem is, especially for high-power trains, you can't get a powered bogie under a floor lower than the traditional coach solebar height, pretty much the same the world over on mainlines regardless of local platform height. That wasn't a concern in Japan on all new infrastructure not shared with anything else but is an an important consideration in Europe because the common continuous low floor technique has the floor pass between the tops of the wheels of traditional axles in wheel boxes, and motors and gearboxes in the space prevent that.
The new Talgo Avril is the only 360kph equipment available 'off the shelf' today with 750mm level boarding throughout. In series production now, it took a long time to be accepted by initial operators in Spain, but should be in service this year. Talgo's split axle design on trailers could theoretically allow a ~550mm floor to pass between wheels if a customer wanted that, so ~915 for UK should be easily possible in a UK car body reprofiling exercise and their shorter cars could allow a slight widening over traditional longer IC cars even within the diminutive British loading gauge.
Alstoms TGV-M configuration of the Avelia product for SNCF takes a different approach with level boarding at 550mm to a door lobby from which steps or a turntable lift can deliver the passenger down to the lower saloon, even lower than the platform. Steps also lead to the deck above, but there is no way through at door lobby height to the adjacent car, maybe because at that height you're not comfortably over the traditional solid axle wheelset used on the articulated bogies. This probably could allow some of the passenger car bogies to be motored if desired in an 'AGV -style' distributed fashion, but Alstom, like Talgo, seems to be promoting the overall weight, complexity, ease of maintenance, and reliability as well as cost benefits of the more centralised power car approach. This is used on Alstoms TGV-Ms and the related Avelia Liberty trains delivered to Amtrak in recent years (also suffering delayed introduction).
Although not yet into the 'true' high-speed league, Stadler have produced the 250kph RABe 501 'Giruno' train for SBB following similar principles demonstrated in their FLIRT series of trains. Low 550mm floors (with some 750mm sections and doors, possibly for future through running to Germany) ramp up slightly at car ends to pass between wheels and over the axles of unpowered articulated bogies. While there are no cars wholly dedicated to traction purposes in this design there are a limited number of 'power equipment clusters' at driving ends and some intermediate locations with traction bogies beneath short traditional height floor sections; otherwise, the rest of the train is continuously lower floor although ramped in places rather than continuously level.
In 2023, DB announced an order for 56 'ICE-L' trains from Talgo along with a much smaller batch of 17 latest Velaro neos from Siemens. Note the L stands for level boarding and I think the order split is a real challenge to their traditional lead supplier. Germany is otherwise steadily improving its level boarding game across the network and its disappointing there hasn't been a high speed product so far that can match the 750mm standard platform height common at most larger stations.
As to Hs2, that's a nice rail network you've got there. Would be a shame if it got locked into 1100mm+ platforms for generations just as the level boarding revolution takes off all over Europe.
There's time to change this. No new platforms have been completed yet and no new trains constructed.
