- Joined
- 14 Jul 2011
- Messages
- 18,644
Class 395s or if you can secure routes into the termini then you could use things like TWINDEXX Express (230km/h top speed apparently) to get more capacity.
Which of the following should happen soonest?
1, London to Bristol then Swansea or Devon.
2, Same but from Birmingham instead of London.
3, London to Brighton then Southampton.
4, Norwich to Liverpool via Sheffield.
5, Edinburgh to Glasgow.
6, A Belfast link via an undersea tunnel.
7, London bypass between HS1 & HS2.
8, An upgrade to a current mainline.
5. would be third in line but like deltic above I also think it would only be worthwhile with HS2 from Manchester or Leeds to the Central Belt unless there was a severe capacity problem between Glasgow and Edinburgh that needed to be tackled.
The BML appears so overloaded that an upgrade would make the WCRM look like a picnic.
What actually are the most congested lines at the moment?
Just a thought here for High Speed to Brighton:
Would cancelling cross London Thameslink trains from Bedford to Brighton and having them end at London. Then have Midland Mainline trains running to Gatwick Airport then Brighton at slow speed like HS1 is like on the Kent coast line instead be a good idea?
I never been down to South coast (except SW) and it looks awkward to get to those areas from North of England by train or road.
I think an HST going there once an hour would improve connectivity.
Or is this idea of mine silly?
