It's actually case of (in sequence):
- Reading the posts of jcollins etc showing routes in the North which have slower stock than would seem appropriate.
- Previous threads including the argument for Turbos on the Thames braches being that it is to create a uniform fleet which cuts costs
- Realising that in a few years time the vast majority of the services in the Thames Valley that can make use of speeds above 75mph will be electrified.
- Seeing a thread title about 156s being cascaded to TPE
- Demand on the railways is increasing, as showed by the suggestion (in the Cross Boundary Route Study draft) for an hourly Bristol-Southampton-Brighton fast service which appears to show more use for 90mph DMUs by Great Western around Bristol.
If you put these points in sequence you will see that the primary purpose of this thread is to solve a problem. I do not know if this problem is being solved by other means. It is just an idea formed to solve a problem. No one has yet showed a better complete strategy to solve the problem even though I have welcomed people to do so many times in the thread. I am not saying that the Turbos should all be cascaded from the Thames Valley. It is just fun to think up and discuss new solutions to problems that one does not know of a solution.
However having said that the number of DMU's in the Thames Valley is likely to be fairly low, so any improvements achieved by moving them elsewhere is likely to be fairly limited (more so if they leave the GW area) with potentially a fairly high price tag (given the potential need for clearance works) if they go somewhere other than routes that already see 16x's.
Also, given how much many on here spit feathers about 3+2 seating, the arrival of some of the 16x's may not go down that well.
Given the suggestion that there maybe a Oxford - Gatwick service at some point, there is likely to be a need for 90mph DMU's to stay to enable that to work between 125mph stock, or alternatively the electrification of the North Down's Line will be pushed through. If it is the latter (possible CP6 scheme) then I hope that they also consider extending platform lengths and/or providing ASDO equipment to enable longer trains to use the line.
