Inactive door control buttons
ess
9 Feb 2010
Is it true that the central line used to be driverless and the door open/close buttons used to work? who decided to do away with that? seems pretty stupid to me.
Furrball
9 May 2011
Central line has never been driverless, it is automatic however.
Door buttons were operational when the stock was first introduced AFAIAA
lewisf
21 Feb 2009
Kingston/Surbiton
It would be nice if the close buttons still worked. Was sitting at Ealing Broadway on Sunday waiting for the train to depart and the inside was soaked!
starrymarkb
4 Aug 2009
Exeter
For the first few years the buttons were in use, then LU decided that all doors should be opened at all stations. I expect when they have a more major refurb they'll be plated over (much like the D Stock)
ess
9 Feb 2010
ealing broadway needs a spectacular roof across all the nr and tube lines to solve that in style. although a more urgent requirement is just a footbridge on the london end of the platforms between tube and nr which would be a good start to make foot traffic flow better
tom1649
5 Jul 2010
The door buttons on the 1996 stock (Jubilee) and 1995 stock (Northern) were in use for an even shorter length of time. I'm pretty sure in the case of the 1995 stock, the facility was withdrawn even before the entire fleet had entered service.
Dstock7080
17 Feb 2010
West London
ealing broadway needs a . . . . . . . although a more urgent requirement is just a footbridge on the london end of the platforms between tube and nr which would be a good start
Coming to that station for Crossrail ;)
tom1649
5 Jul 2010
Central Line (1992 stock)
Jubilee Line (1996 stock) - the former, now scrapped 1983 stock on this line had them too.
Northern Line (1995 stock)
Metropolitan Line (S stock)
The D Stock on the District Line had them until they were refurbished in 2006 - 2008. At this point the buttons were plated over.
JoeGJ1984
7 Nov 2010
Are the S stock buttons active? Or are they just like all the other buttons and do nothing?
jopsuk
13 May 2008
Active- they're there to help the airconditioning, and if stopped at a station for a few minutes (such as at terminals) any open doors will shut. I think the driver may still be able to open all doors at once at busy stations?
transportphoto
Quizmaster
21 Jan 2010
They will. S stock doors always open - then close after 45 seconds - the buttons become active - if you press the button the door opens - then closes after 45 seconds - repeat until driver 'closes' the doors :)
45 seconds from the last movement through the door, I think it would cause a few people some panic if it was 45 secs from opening and there were still people going through ;) :smile:
causton
4 Aug 2010
Oops! Makes more sense - I thought it closed as soon as possible after 45 seconds i.e. if someone left at 44 seconds it would wait until they were out then close. Didn't realise it reset the timer :)
transportphoto
Quizmaster
21 Jan 2010
I may be wrong, although I have always thought that it reset the timer. Thats certainly my experience with other Bombardier stock :smile:
TP
JoeGJ1984
7 Nov 2010
Would it be possible to trap somebody in the doors of an S stock by pressing the door close button as they are walking through? I think they had problems with this with, e.g. the 1992 stock, which was the reason for them not being used.
jon0844
1 Feb 2009
Don't they have a sensor to see if people are alighting, which restarts the counter?
That can only work if you're ON the train though, so they'll shut on you if you are boarding when they are set to close. I'm sure on HEX, the doors shut quicker than 45 seconds.
Mike395
23 May 2009
Bedford
S Stock only have door open buttons, not door close ones :)
tsr
15 Nov 2011
Between the parallel lines
The section between Woodford and Hainault was pretty close to being "even more" automatic by way of a trial run a number of years ago, with extra equipment (was it called FACT?) being tested in the Roding Valley Area, if I remember correctly.
