Southport is a completely different tier of service to Windermere. But the power of a line user group shows!
It's an important and will used line, however it's not a "quick win" in terms of electrification that Windermere Would be
Reduced wire height as per Paisley Canal solution?coast under it with power off and pantograph down.
As the route used to be double track and in most places the track is under the centre of the arch, my hope is this would not be a problem. But I am not an engineer.Could the track bed be lowered under the bridge?
Indeed. Wigan Wallgate bridge poses a significant complication. I do believe it should be electrified, but it'll require some very expensive work* to get there. It may prove cheaper just to use battery fitted EMUs which would charge between Manchester and the junction for North Western once Westhoughton is wired.
* Either purchase everything sitting on the bridge, demolish and replace, a lengthy closure for a structural rebuild (it's already "shored up") to allow the trackbed to be lowered, or rebuilding the station slightly further west so it is possible to coast under it with power off and pantograph down.
(I cynically think the biggest issue is the whole area is now LibDem and the Govt will want to reward a Tory Red Wall seat/council as proof of levelling up. Wires to Blyth and Ashington may therefore happen first!)
Yeah - I don't think there is any project with as much benefit out there!Single track and only half the distance in the National Park, and even that not in the most scenic part.
On a cost per mile project to gain a much greater electric hauled distance with through trains this really should be at the top of a priority list.
The battery idea has been floated, but that makes zero sense - the cost of implementing a battery sub-fleet would almost certainly be higher than electrifying.Clearly it makes sense to electrify it. Clearances are generous, it would remove a comparatively short section of non-electrified rail from a heavily used tourist route, meaning no need for diesel/awkward bi-mode sub fleets. It could be worked from the general pool of electric units and strengthened potentially as needed.
It's single track, so a line of stanchions would be little more obtrusive visually than a line of telegraph poles.
People objecting to this really need to have words with themselves.
Disagree. Fuel and engines or batteries carried from Manchester Airport to Oxenholme which then needs a small microfleet. Cue trains cancelled and replaced by buses when no trains available. It is a simple very short line. Get it done.
Given Barrow is probably less likely to be wired than Windermere (at least in the shorter term), then to cater for interworking a bi-mode fleet could be the answer although potentially having a bi-mode fleet would also weaken the case for wires to Windermere.To be fair unless you do Barrow (or truncate that to Lancaster and do Windermere from the Airport hourly instead) there's still going to be a need for bi-modes, and Windermere and Barrow interwork. I'm starting to think sticking 3-4 more 80x onto the forthcoming TPE order and having them operated by TPE as they were a while back would be the best way; the quality improvement would get more people travelling in the added capacity.
Interworking is only the outcome of the current timetable and the unit diagramming. Either could be changed to keep the all-electric Windermeres shuttling and the bimodal Barrows doing their diesel bit west of Carnforth.To be fair unless you do Barrow (or truncate that to Lancaster and do Windermere from the Airport hourly instead) there's still going to be a need for bi-modes, and Windermere and Barrow interwork. .
Even if some Barrow services turned at Lancaster (and potentially some at Preston adding 21 miles each way under the wires) there would still I think be sufficient Furness business to justify several through trains to Manchester each day.
Just because Windermere and Barrow are currently inter-worked, doesn't strike me as a good enough reason not to go ahead with a quick win electrification.
Rump routes are fine, however they would likely involve some diesels working over them. Windermere would remove diesels from an already electrified rump route. Perhaps Windermere electrification could be tacked onto a larger electrification scheme.
Do the supports of the overhead lines have to be grey? In somewhere like the Lakes I'd want them painted green or some kind of vegetation camoflauge if they ever happened. Round here they have had to make mobile phone masts look a bit like trees to fit in.
The timetable I'd go for would be two-hourly to each, with the other hour containing a shuttle with the same 80x (Windermere) or a local service from Lancaster to Carlisle using a 156 timed to connect with the Windermere (Barrow). That's roughly what it was when TPE were last involved.
I'd still do it with moving them to TPE. 80x can of course run on the wires! Barrow should be wired too but that won't be soon.
Thanks, I hope that's taken in to consideration if we ever get electrification across the Pennines.The line doesn't spend an awful lot of time running through the very scenic bits, but yes, you can paint them any colour you like. Almost all German ones are a sort of pastel green.
TBH, the WCML over Shap is pretty unobtrusive. But if they do Windermere with trolley wire it will be even more unobtrusive. And it would no need any switchgear - just an isolator at Oxenholme.Barrow is similar to the Southport line. Worthwhile electrification at some stage but not a quick win.
Would it really? TfW have a bi-mode subfleet of 769s and electrification is certainly expensive, epecially as it often goes dealyed and overbudget as with the GWML and even the MML. BMU 195s would be the answer, and would be mechanically mostly similar to the existing 195s and would require no more than a conversion course and some expanded maintenance competance.Yeah - I don't think there is any project with as much benefit out there!
Just out of curiosity to those against Windermere electrification, if not something as simple as Windermere, then what? Seems like a case of being against any new electrification at all, and then people wonder why the railways are in such a dire state.....
There is little risk with Windermere. No mines, known geology, no complex junctions. You could close it for a few weeks in Feb and get the job done quick. And as its single track no complicated cantilevers. So no very deep piles. Dunno what a pile will do if it hits bedrock, mind.Not all electrification projects have equal risk of delay or overspend though. As a general idea, the larger and more complex a project is, the more chances there are for overspend or delay. This line is very short and simple, so there's relatively little that can go wrong. There's also some risk for scope creep, but if that's kept at bay, this should be a relatively cheap electrification project
The RMT would just love that (not)!Its needing electrifying for years. A 4 car 331 would be perfect for this service with DOO
Electrification should focus on more important rump routes first IMO, such as the TP core, Calder Valley etc.
