I'm visiting Koblenz in a few weeks time, and I will be visiting all the usual areas, Mainz, Boppard, Cologne etc, using a FIP.
Does anyone have advice on days out or fares, or even the best trains for the scenic lines
Thanks
The Panoramawagen is 1st class, so unless you have 1st class FIP I would save it for the Rhine Gorge from Koblenz to Bingen (better done downstream for uninterrupted views of the river though). I think I'd opt to spend the extra on a meal in a restaurant car (but not many of the trains have one, so check - EC8/9 and 6/7 are SBB cars) and use both right and left bank routes for eg Mainz and Cologne to get the best views - or a steamer of course, do you get FIP on them?Try to ride EC8 (Zürich -> Hamburg) or EC9 (Hamburg -> Zürich) between Cologne and Koblenz in coach 263. This is an SBB Panorama coach, giving you great views along the Rhine Valley.
Certainly the mosel line to Bullay and then the branch to Traben Trarbach are a must. To the north, Remagen with its famous ruins of a bridge known from WW ii history and Hollywood. If you can take a boat towards Bingen or Rüdesheim. You get a wonderful view in both lines in the Rhine.
By the way, the train ride among the Lahn from Koblenz to Limburg is also very scenic.
Koblenz station has Lots of freight passing.
There ist also a DB railway museum in Koblenz.
So is Neef still an unstaffed halt that way, DuesselM ? And I think there was another, Eller.
Oh dear ..... maybe I'll have to try and visit those place now some time .... the work does seem to keep piling upNeef and Ediger-Eller are still very much in business; in fact, so are all the Moselle valley stations. E-E, being between the Kaiser Wilhelm Tunnel and the river bridge, is still a Station in operational terms (but it probably only has a ticket machine and shelter).
Edit: beaten to it by duesselmartin.
Also enjoyable is a trip on one of the KD boats, with the train passing either side of you. We did St Goar to Bingen, long enough to get a meal on board. I think the steam-powered Goethe is still running - April-October 0900 from Koblenz apparently (see https://www.k-d.com/schiff-chartern/charteranfrage/kontakt-charter-danke/flotte/rms-goethe/ )
