The two track section Hitchin to Cambridge compounds the issues too. Generally my observations commuting are that it's the timekeeping on the stopper which causes a lot of problems, in both directions, especially as the services interwork at King's Cross too.
The December recast should help by splitting up the stopping service at peak times - that thread across Welwyn slow to fast to slow doesn't work reliably enough. It's too common for the stopper to be 5 late at Stevenage, held for a fast at Knebworth to then fall behind a Moorgate stopper and lose more time.
I’m not sure turnaround times are that much if an issue - the stopping services get over 20 minutes at the London end, and considerably more at the country end. It’s only really at Kings Lynn on the fast services where things are tight, and I guess the constraints of the infrastructure are a substantial cause of this.
Where the up stopping services seem to lose time is being stuck behind Cambridge to Brighton services, whose Cambridge turnarounds are short. This will actually get worse in due course, when Cambridge South opens.
From a signalling point of view, I find there’s insufficient urgency in pushing up services through the Letchworth to Welwyn section, and once this happens it doesn’t take much for the service to then be stuck behind the 717 starting at Welwyn. Again, in the past use would have been made of the infrastructure to try and correct this (crossovers at Marshmoor, Potters Bar to use the up fast, or use of the up slow no.2 inwards from Alexandra Palace), but this simply doesn’t happen now - and this isn’t always a case of insufficient space on the fast lines, as it can happen at the same extremes of the day as well.
I guess one quick win would be to make use of both platforms at Kings Lynn, which would essentially add half an hour to the turnround time there - albeit at a cost of two extra units having to be out on the railway, albeit without incurring any extra mileage. For this to be effective this also relies on driver turnarounds being similarly lengthy, though with Kings Lynn being a crew depot presumably there’s a fair few services which have a fresh driver take the train south.
Are the staff at York overloaded with work so just unable to be across everything or is it a loss of familiarity and experience with a route to know the best way of resolving an issue on a real world basis rather than a headcode basis?
Shouldn’t really be lack of familiarity, as control has been there for some time now that the signallers should know how to work efficiently.
It does seem that there was some loss of expertise when the move happened though. The signallers now either don’t want to deviate, or are discouraged from doing so.
