Leaked HS2 report claims scheme ‘fundamentally flawed’ - FT
Metrailway
1 Jun 2011
Birmingham/Coventry/London
From the Financial Times:
Rail project in ‘precarious position’ and may exceed £56bn budget by as much as 60%
  • Successful delivery appears unachievable, says report’s author
  • Project hit by series of controversies
  • Scores of people yet to receive compensation
Racing through the countryside at 250mph, the planned new high-speed train line from London to the Midlands and northern England should be one of the fastest in the world. But it is also set to be one of the most expensive.
A leaked document prepared for the government’s Infrastructure and Projects Authority warned shortly before the High Speed 2 railway was approved by parliament in February 2017 that the scheme was “fundamentally flawed” and would overshoot its £56bn budget by as much as 60 per cent.
The December 2016 document, marked “sensitive” and “not for publication”, said Europe’s biggest infrastructure project was in a “precarious position” and would be “classified as ‘failed’ by any internationally recognised definition”.
It added that HS2 was “highly likely to significantly overspend, 20 to 60 per cent”, which would increase the cost to as much as £90bn.
The project management capabilities of HS2 Ltd, the taxpayer-funded company charged with building the railway, had fallen “well short of best practice”, and its executive team lacked “cohesion and common vision”, said the document.
It called for “greater transparency and frankness” about the timeline, costs and benefits of HS2, which will run from London to Birmingham in its initial phase, and later to Manchester and Leeds.
‘The government clearly misled parliament’ Tony Berkeley, a Labour peer and former engineer who worked on the High Speed 1 railway between London and the Channel tunnel, said: “The government clearly misled parliament by hiding this devastating report on HS2’s performance and cost overruns.
“If parliament voted for HS2 on false premises that calls into question the legitimacy of the project.”
Read more...
There is a lot more info of cost overruns and problems in the FT article linked including the fact that HS2 have only bought 20% of the property required for phase 1 but have spent £1.6bn of the £2.8bn allocated budget.
bnm
12 Oct 2009
Where's @Snapper to refute this worrying, both in content and the fact it was suppressed, report?
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
While I realise the press sometimes is unable to reveal its sources nevertheless for this article to have any credibility we really need to know more about the report. Who actually wrote it and what were their terms of reference? Essentially does it contain real evidence of shortcomings or is it a politically motivated hatchet job based on supposition. As per bnm if the allegations are true then it is worrying but how reliable is the report?
Metrailway
1 Jun 2011
The full FT article quotes the report author. His name is Paul Mansell, an independent adviser who has worked at HS2 Ltd at the Infrastructure and Projects Authority’s request. (Infrastructure and Projects Authority is a HM Treasury/Cabinet Office agency which advices both departments on big infrastructure projects)
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
Thanks for that. A quick search reveals Paul Mansell to be something of an expert in high-level project management. As such his report is certainly to be taken seriously. I wonder if any FT subscriber here would care to provide a little more detail...?
47802
8 Oct 2013
I suspect he will be right, it will be vastly over budget and most of stage 2 will never be built.
158756
12 Aug 2014
It looks similar, albeit on a much bigger scale, to the new platforms at Manchester Piccadilly. Phase 1 will deliver all the WCML capacity benefits, and then the western branch at least will be spending £20bn or whatever to save 10 minutes.
class26
4 May 2011
It will save more like 30 minutes but once again do we have to repeat this is NOT about saving time but about increasing capacity
bnm
12 Oct 2009
No need to be expensively engineered for 250mph then.
bnm
12 Oct 2009
Because we are reminded constantly that HS2 is about capacity, not speed. So, if that's the case it's just wasting money to engineer it for 250mph operation.
Lower speed means reduced headways means more trains. Save a fortune too.
Not that I'm sold on either capacity or speed though.
paul1609
28 Jan 2006
Wittersham Kent
https://www.hka.com/expert-post/paul-mansell/
Ive been to a project management lecture by him.
When was the last time a major infrastructure project in the UK actually worked?
Also, wasn't the HS2 budget packed with an absolutely enormous contigency, specifically to stop this from happening?
jyte
27 Oct 2016
in me shed
Arguably Crossrail.
Yes it's run over on budget now, but that's primarily NRs fault. If Crossrail was an entirely new-built line from Paddington to Abbey Wood, chances are it would have come in under budget.
Ianno87
3 May 2015
Once you've built a line for new capacity, the marginal cost of adding high speed is relatively low and offers extra benefits that outweigh the extra cost.
Also, lower speed meaning lower headways meaning more trains only works if the whole system can take the extra trains, not just the plain line headway element (remembering that HS2 will already permit a very good 3 minute planning headway anyway). Tunnels are also a limiting factor on the service headway for example. So going slower through the tunnels increases the headway, not reduce it.
NotATrainspott
2 Feb 2013
The maximum capacity of HS2 is dictated by what can be turned around at Euston. Dwell times at the terminus have to be on the order of half an hour because these are not metro trains, but long-distance trains used by a different sort of passenger in a different sort of way. 11 platforms enables a comfortable 20tph maximum. Slowing down the trains along the route doesn't magically make them turn around at Euston any faster, so any increase in capacity would require extra platforms.
jon0844
1 Feb 2009
Given the line will be around for a LONG time, once you've got that all done then you have time to build a new terminus station, without having to upgrade the mainline again.
It means there's some scope for future expansion, which is another good thing. So many projects are completed and then found to be insufficient.
AndrewE
9 Nov 2015
...which is why I can't understand the opposition to sending the trains further south before they terminate. I imagine 2 or 3 well-spaced but strategically-chosen interchange stations in west London with 4 or 6 platforms each would handle the trains, and a branch to Heathrow plus a new line to Gatwick or Brighton would be very useful in cutting out some passengers' need to change lines and/or stations.
johnmoly
26 Dec 2014
liverpool
.......will never be built.
Just what I and millions of others suspect, it will start at London and end in Birmingham, mainly for the London commuters.
jon0844
1 Feb 2009
Even if that were true, which I doubt, the freeing up of the WCML benefits many more people so it could still be argued as a success. But we need to build the whole thing, and more beyond that. HS3, HS4..
quantinghome
1 Jun 2013
This blog entry responds to the same story in the Sunday Times:
https://paulbigland.blog/2018/07/22/more-anti-hs2-gilligoonery-in-the-times-today/
Points to note: the report was dated December 2016 (so why is this news?), there's no context to the quotes from it, and it's the product of the usual anti-HS2 journos. The DCA rating system seems particularly strange - it gives a 'red' rating for IEP (meaning successful delivery is unachievable), but IEP is now being delivered. HS2 has a better rating - red/amber (unchanged from previously), which puts it in the same category as most other rail projects.
MarkyT
20 May 2012
Torbay
Weirdly I was able to read this, yesterday I think, in the FT despite not being a subscriber. I can't see it now. Below the line was interesting with a number of commenteers suggesting there was not the usual FT quality of rational argument evident in many of the comments. There were many one liners, troll like accusations of fraud etc. Some speculated there was some organised anti-HS2 commenting going on, almost as if this old news story had been planted specifically to attract it. I wonder if stop HS2 have got some recent dark funding and impetus from some source, maybe Koch supported organisations like Cato, Reason etc who are rabidly active in anti-transit activity in the US. If its on wheels, doesn't use oil and isn't individually owned by its driver, or is planned by some arm of the state, they oppose it on principle. They stand on the principle of protecting taxpayers and American values but their undisclosed funders are often speculated to be airline, automotive and oil interests. These organisations have professional activists who are paid to go out and canvas in areas where schemes are being proposed to swing votes against all forms of transit. They're in a desperate battle currently to try and overturn a number of headline rail projects in the US, notable California's HSR. They are afraid of the first such scheme being seen as successful and paving the way for further projects, so they're determined use every underhand political technique in the book.
NotATrainspott
2 Feb 2013
That would cause a significant increase in costs for not a lot of benefit. HS2 Ltd looked at this back in 2009-10 and they found that the best option was a major terminus in Zone 1, and the only viable site for it is Euston.
Taunton
1 Aug 2013
Not even that. What demand is there from a dilapadated east-central part of Birmingham to commute to London? Euston isn't even connected directly to The City or to Canary Wharf.
It's also justified using some eye-watering fares income. Chiltern can just up their game, charge normal fares, and scoop quite a lot of the traffic off.
Ianno87
3 May 2015
....Old Oak Common (where all HS2 trains stop) *is* [or, rather, will be] directly connected to The City and Canary Wharf, via the Busy Lizzy. (Also, last time I checked, Euston is already connected directly to Moorgate and Bank by way of the Northern Line).
Eye-watering fares income does not necessarily imply eye-watering fares (normal fares, just lots of them).
I've just done Euston-Birmingham on a Pendolino today. Was fully loaded 11-car both ways, with exactly the same Chiltern fares competition as you suggest. Chiltern can only 'up their game' so far as the capacity as the Chiltern Route allows.
So it only goes to Birmingham? There is no connection north of Lichfield on to the Trent Valley? must have missed when they removed that part of the route!
Muzer
3 Feb 2012
Full article
The leaked HS2 report was written by Paul Mansell, an independent adviser who has worked at HS2 Ltd at the Infrastructure and Projects Authority’s request.
He has also been a project assessment review team leader at the authority, which advises the Cabinet Office and the Treasury on big infrastructure schemes.
According to the government’s so-called traffic light assessment system for big infrastructure projects, HS2 has received an “amber/red” rating by the authority for each of the past six years — meaning there is a “high risk” of it not delivering value for money.
But Mr Mansell’s report suggests the rating should have been red: the successful delivery of the project “appears to be unachievable . . . the project may need rescoping and/or its overall viability reassessed”.
Vanity project championed by the Tories
Nick Macpherson, Treasury permanent secretary from 2005 until March 2016, said HS2 was viewed as a political vanity project — it had been championed by former prime minister David Cameron’s government, including his chancellor George Osborne.
He added the Treasury generally preferred incremental improvements to the railways, saying it was not a priority “to make it easier to come from Birmingham to London”.
Mr Mansell’s report is just the latest controversy to hit the HS2 project, which went ahead in spite of 2,588 objections by a wide range of people and organisations, as well criticism by MPs and peers, and the National Audit Office, the public spending watchdog.
Simon Kirby resigned as HS2 Ltd chief executive in September 2016 following a report that, according to people close to the company, was critical of boardroom governance. HS2 Ltd said he resigned to take up a job at Rolls-Royce.
Mr Kirby, who while at HS2 Ltd was the UK’s highest paid civil servant on £750,000, was later accused by MPs of approving redundancy payments to employees worth almost £2m against the instructions of the Department for Transport. He denied any wrongdoing.
In March 2017, HS2 Ltd scrapped a £170m contract to design the second phase of the project with US engineering group CH2M after allegations of a conflict of interest.
Rival bidder Mace highlighted how Mark Thurston, HS2 Ltd’s then newly installed chief executive, was a former CH2M employee.
Evidence of cost overruns is growing
More recently, scores of people have complained about low property valuations and delays in compensation payments after their homes and offices were requisitioned by HS2 Ltd because of their location on the railway’s route.
HS2 Ltd is engaged in the UK’s largest set of land and property purchases since the second world war, and flaws in its valuation methodology were raised in two confidential reports for the company in 2015 by Deloitte and PwC.
Meanwhile, three former senior executives at HS2 Ltd have said they were dismissed in 2015 and 2016 for warning about significant inaccuracies in the project’s official budget for buying land and property.
Evidence of cost overruns is growing. HS2 Ltd has bought just 20 per cent of the properties along the first phase of the route, but already spent £1.6bn of the £2.8bn it has allocated to the exercise.
HS2 said it did “not recognise or agree with” the analysis in Mr Mansell’s report, “or the figures it contains”.
“The Infrastructure and Projects Authority recently described the HS2programme as ‘on target to be completed on time and on budget’,” it added.
HS2 said it had added “further strength” to its executive team with the appointment of a new finance director and chief operating officer.
Neither Philip Hammond, the chancellor, nor Chris Grayling, the transport secretary, saw Mr Mansell’s report, according to government officials. They said Mr Mansell was not tasked with assessing HS2’s costs and that ministers disagreed with what he concluded.
The transport department said: “This is an internal report representing an individual’s personal views. We are keeping a tough grip on costs and HS2 is on time and on budget at £55.7bn.”
PwC and Deloitte declined to comment. Mr Mansell was unavailable for comment.
absolutelymilk
18 Jul 2015
Indeed, and in fact increasing speeds reduces time taken for the journey, so passengers have less time to make mess/fill up the toilets -> less dwell time
AM9
13 May 2014
St Albans
- and doesn't it require less trains to acheive the same capacity if each return journey takes less time?
Taunton
1 Aug 2013
Which points "north of Lichfield" are suggested for London commuter traffic?
