YorksLad12
Hello,
Some of you will recall that the (Bradford-)Leeds-Wakefield-Sheffield-Nottingham service was in the Northern franchise in 2016 and has been dropped. It would, however, have provided much-needed end-to-end capacity, especially in the peaks, and would have been faster than the via Barnsley route. So I had a think about it, and wanted someone to check my sums.
Let's say that this service uses the xx29 departure slot from Leeds, which conveniently is also by services to Westgate (and Pontefract/Knottingley), not calling at Outwood. The service behind will be an LNER one, also stopping at Westgate, so the semi-fast should have reached Moorthorpe in plenty of time. From looking at similar timetables along that stretch I reckon xx42 for Westgate, passing Moorthorpe around xx56.
By an amazing co-incidence that puts it nearly in the path of the York-Sheffield Dearne Valley service. Well, it does at 0953-ish. If it manages to avoid all of the freight in the area it would arrive in Sheffield around xx19. It might have to avoid Rotherham Central, though there is space for a call; a call at Meadowhall should also be possible. Unfortunately, the Nottingham service leaves Sheffield 12-ish minutes earlier, which means waiting for the Picadilly fast (TPE) and Picadilly stopper (Northern) to go first if we want to maintain that connection.
Returning would be a bit harder: Departing Sheffield around xx34 (with a knock-on for the Huddersfield and Lincoln services), Westgate at xx10 to pick up the existing path and arrive Leeds at xx24. And we'd still miss the incoming service from Nottingham. And northbound departures would be a bit bunched (xx15, xx21 and xx34) compared with southbound from Leeds (xx11, xx29 and xx48).
The slot I picked is the second Leeds-Pontefract-Knottingley service, which would be better (and more quickly) served just by doubling up the existing route via Castleford. That would also mean pulling the Hallam Line stopping service, at least between Leeds and Castleford/Wakefield Kirkgate, to free up the path and platform. As discussed in threads previously, stops could be made on the semi-fast via Barnsley at Normanton and Darton to maintain connections. There's slack in the timetable, and via Westgate is faster anyway for end-to-end passengers.
The only real losers would be Moorthorpe and Baghill towards York, and Sherburn-in-Elmet and Baghill towards Sheffield. With two return journeys per day I doubt many would be inconvenienced. And if you really wanted to you could extend the now Wakefield-Knottingley service northwards to maintain Pontefract-York connections.
Do my sums stack up? Or have I completely lost it?
