GWRjake
I've just returned from Canada where I was amazed to read that their freight trains can be up to 4km long! But how long do freight trains here get?
Whilst we were on The Canadian in May we were told that one that passed us one night was 3 miles long, and we counted 230 wagons on another one, 2 locos on the front, 1 in the middle and 1 at the back.
With reference to the FRA ECP braking standard - the objective maximum length is twelve thousand feet.
You can see many long US freight trains on Google Earth, more than two miles long is not unusual. There are many reasons why British trains are not as long, not least coupling strength. In North America they use knuckle couplers rather than screw couplings.
Longest WTT freight these days probably has to be car trains that regularly run at around 2200-2450 feet.
Ah, yes.I thought that we had gone metric years and years back. . . . .
Anyway 2450 ft equates to approx 746 metres / 817yds
Sorry to stop you there drive. You've set off the HAB detector. Axle 460. Can you check and report back please
Yes I was in British Columbia in summer 2013 on a road trip and seeing many extremely long freight trains was was very impressive.
I never understood why the UK freight operators didn't/don't properly get together (like the AAR) and agree on a set of standards. Eg a standard UK knuckle coupler for freight locos and wagons, and a single multiple working system for locos. It seems farcical to me that we still have many incompatible systems, and it will make it difficult to run long freight trains at speeds compatible with modern passenger ones. As swills says as the get longer they get heavier and slower. We could double up as they get longer to mitigate this but the new the new 68s are incompatible with the 59s, 66s, 67s and 70s. In addition many freight wagons can't couple together and you can't couple certain wagons directly to locos! Plus the reliance on screw couplings means hauling round a load of heavy buffers. Not exactly efficient.
Having said that, DBS coal wagons have AAR knuckle couplers, so why don't their coal trains run at 775m long, with two locos if necessary?
1 SLU equates to 21 feet. It really shows how the railways are changing when you run a 90+SLU freight over a route with loops than can only take half that length!
I understand that 107 bogie wagons in Canada equals 1 mile in length if that helps.Whilst we were on The Canadian in May we were told that one that passed us one night was 3 miles long, and we counted 230 wagons on another one, 2 locos on the front, 1 in the middle and 1 at the back.
The situation in the UK is less clear-cut. In a smaller country loads per train are usually smaller too, because the time to gather enough payload for a long train becomes more significant relative to the journey time. And we have a complicated railway crowded with passenger trains so long freights are often difficult to accommodate. Also European railway have standardised on buffers and screw couplings, so having the same in Britain allows through trains to Europe and (perhaps more importantly) suitable UK gauge wagons to be hired out either here or on the Continent.
Running freight trains at passenger speeds is difficult too. Track forces increase dramatically with both axle load and speed, and when EWS trialled a 90mph intermodal freight the loads in the containers had to be limited. Brakes would have to match the greater decelerations that are needed at higher speeds to stop within the same signal spacings, but would need to dissipate much more energy because the freight train is that much heavier. And much more power would be needed if a freight train was to accelerate like a passenger train and sustain the higher speeds on gradients.
It should be noted that the Chiltern (AAR MW fitted) 68s can work in multiple with 59s, 66s, 67s, 70s and 73/9s using the AAR! Most likely has never/might never happen, but very possible without any further mods.
Is that the case? I heard elsewhere that they've been fitted with an incomplete version of 'AAR', capable of receiving input from the DVTs but not suitable for multiple-working, even within the subclass.
That was specifically in contrast to the 73/9s, which apparently do have proper AAR compatibility.
Whilst not technically a freight train, we do have the HOBC (High output Ballast cleaner). I believe that's over 2000ft?... Someone will no doubt correct me on that!.
