LNER Azuma (Class 800/801)
23 Nov 2015
3 damaged coaches have been shipped back to Kasado, Japan, the remainder of set is at Doncaster Carr Depot.
I wouldn’t be surprised if three replacements are constructed and magically come back with the same vehicle numbers.
DannyMich2018
19 Dec 2018
They may have more diesels than before, but two of the new ones have either not been accepted yet or are accident damaged. The advantage of an HST was that if one power car was damaged you could put a replacement on, rather than losing the entire set.
They also, of course, used to have the ability to hire in an HST set (or even two) from EMT on Saturdays.
Of course the HST's have gone and been replaced with 800/1, there's only 11 of these currently and the number of Class 91s sets withdrawn is more than the number of Class 801 nine cars available for service hence 5-car services common. According to a recent issue of Today's Railway UK the only services supposed to be booked for single 5-car sets are the Lincoln services.
47271
28 Apr 2015
To be fair to them, I'm doing a huge amount of travel on LNER at the moment and in the last two months haven't had a single problem caused by IET availability or reliability. I don't do Lincoln, and very rarely Leeds, but King's Cross, York, Newcastle, Sunderland, Edinburgh, Glasgow, Aberdeen and Inverness have all been spot on as far as the train itself is concerned. Not one sawn off 5 car unit has turned up, although I see that I'm booked on one 5+5 later this week, so maybe my luck is about to run out.
This is more than I can say for Transpennine and their use of the train type.
My only slight complaint is that I've usually found the cabin a bit cool for the time of year, but I've totally got over my dislike of the seats.
Marton
9 Nov 2008
Had the opportunity to use a TPE 80x today.
I thought the first seats were more comfortable than the Azuma ones.
The ride was just as noisy and lots of lateral movement, but I presume the bogies etc are the same.
greyman42
14 Aug 2017
Yes I have noticed the same. If you are travelling for much more than an hour, you start to notice it. The temperature setting should be turned up. I didn't notice the same problem on the mark 4 or mark 3 coaches in the past.
3973EXL
2 Feb 2017
johntea
29 Dec 2010
I saw the inside of a driver cab on an Azuma this morning...I never realized how spacious they actually were! I thought I had walked into an episode of Dr Who :D
Out of interest why does the control panel have a plug socket (and what looked to be USB ports) available? Are the guards / drivers allowed to charge up their phones in there?
PomWombat
1 Jul 2018
Interesting to see seat covers on some of the end seats, with instructions to use then for luggage rather than sitting.
Not sure whether I saw that in a 5 or 9, but definitely a bi-mode.
TheBigD
19 Nov 2008
It's just the 9 car Azumas. Those seats will be replaced by luggage racks in the coming months.
westv
29 Mar 2013
I saw the inside a few weeks ago. Yes, the space looks huge although I have no other cab to compare it to.
800001
24 Oct 2015
Pm
It is for the drivers work Ipads. It is optional of they use it, and can be used as a driver advisory system for speeds etc.
It has the calling points, if train is early or late can advise to coast and ease off on speed etc.
Indigo Soup
17 May 2018
Presumably someone decided that drivers would do it anyway, so better to provide official means of doing so than to have them using charging points in the passenger saloon. It also makes a lot of sense if they (or other crew whose duties take them into the cab) using any kind of portable electronic equipment in the course of their duties - which presumably includes a mobile phone, but could be any number of other things. Even if it's just for specialised engineering diagnostic systems, using a USB port is probably cheaper than designing a bespoke connection!
Meerkat
14 Jul 2018
Bit off topic, but would TMS etc be considered a security risk and therefore not have standard connections? Lots of IT issues come via USB ports....
Indigo Soup
17 May 2018
Probably cheaper to have the USB ports leading to the train systems behind a locked panel - though other standardised connectors are of course available!
J-2739
30 Jul 2016
Now sitting on an Azuma.
Pretty much the same as the 802 I was on last week, although with seemingly better acceleration, and improved ride quality.
EM2
16 Nov 2008
The home of the concrete cow
Had my first Azuma on the way back from York yesterday, with a 91 on the way there.
I found the Azuma quite comfortable, I think the seats will soften with use like they did on 395s, the ride was fine and no worse than the 91, but a bit noisier (I think the aircon was the issue, although I was also sat under the pan).
westv
29 Mar 2013
Yesterday standard class passenger door at far end of the train (one nearest the driver cab) was out of use. Hopefully a one off.
palmersears
20 Sep 2011
How many of the Azumas are in service now? Off to Doncaster on Monday for the first time in a while, and want to gauge just how many I'm likely to see.
800001
24 Oct 2015
All of the 5 car 800/2s and 5 car 801/1s.
800102-800113 all in use (800109 out of service due to Neville Hill accident, and 800101 is due to leave Eastleigh on Monday and start it's fault free running.
801203/205/207/209/211/213/217 all accepted and in service.
18 Dec 2009
At certain stations it will be locked out of use. Aberdeen and Inverness for example. There is no door control panel at that door so it is to stop people running for it mid despatch and causing delayed departures.
800001
24 Oct 2015
That door should not be locked out.
Only doors locked out, will be those preauthorised and set up by the Selective Door Operation system, ie those doors that are off the end of platforms.
Kite159
27 Jan 2014
West of Andover
Random question, when the Azumas get diverted via Cambridge (like today), do they run on electric as far as Ely before changing over to diesel for the section towards Peterborough, or do they have to change to diesel before hand due to power limitations north of Cambridge?
Kieran1990
29 Feb 2016
think they run on diesel from the Cross to Peterborough... not sure they are cleared on electric over the Cambridge route.
TheBigD
19 Nov 2008
Reported elsewhere that they change over near Royston.
