As I understand it (as a Southerner now, but former resident of the North West), Liverpool to Manchester is being wired already, with the Manchester to Leeds TPML(North) route due to be also done.
Given TPEs routes are as follows: Liverpool-Scarborough, Manchester Airport-Newcastle/Sunderland, Manchester-Hull; the only one that could be converted to EMU is the Manc Apt Newcastle one. 185/170s will have to remain to cover the others as the destinations are all off the wires. I dont know what the Northern frequency down the TPML(N) corridor is but I thought most services came from various branches & connections and similarly involve off-the-wires sections so wont be able to go EMU either.
What really is the point of electrifying a route when only a minority of the services on it will be able to take advantage and be converted ? it doesn't really help cascading either. It just seems a lot of money and effort to not take all the benefit if you had used it on an end to end route as is usually the case with electrification schemes.
What, assuming there is something (which I do assume !), am I missing?
The next phase seems to be the MML which leaves the TPML hanging wouldn't it be better to complete the TPML and branches (which are also shared with the ECML) leaving diesels on the Midland (since the 222s are young and if more branches in Yorks/NE were converted, bi-mode IEPs could replace HSTs on the MML with EC being an all electric affair as it really should be). Or just refurb the HSTs ala S.West plans (since even the two would only require a small part of the current fleet so taking the best is still possible).
Are we trying to do it all partially at once, rather than doing each bit properly in turn? And wouldn't it be easier/cheaper to just continue electrifying the TPML spurs/branches rather than start the entire process again on the MML to then come back 5-10 years later and pick up the TPML again ?
On another topic, I'm assuming one impact of HS2 (reason for doing !) is that further speed/major capacity improvements to the WCML, ECML and MML are moot since they now exist a) to handle long distance high speed traffic until HS2 opens and as such need to be left undisrupted to do that and b) when it does open, will be more about slower, short-medium distance and freight services so 140mph and all that will be irrelevant ?
The implication from that is that IEP, for ECML/MML high speed, high capacity service is more an interim solution and thus could be relaxed a bit spec wise.
[Although haven't we been here before with "uber solution" APT and "interim" HST... remind me what happened and which endured....]
