Well I suppose you could route via Newton-le-Willows?Could somebody please clarify the route from Crewe to Victoria - where do you branch east off the WCML? Does it involve a reversal?
Crewe to Warrington as per Avanti, then Warrington to Victoria as per Northern's Chester-Leeds services.Could somebody please clarify the route from Crewe to Victoria - where do you branch east off the WCML? Does it involve a reversal?
The grapevine does suggest that WMT is really third-wheeling in the HS2-Avanti relationship, and is going to be the last to receive track access rights behind Avanti and Open Access.I doubt that DfT will permit a "budget" Manchester-London service with significantly lower fares than on Avanti.
It would rip the heart out of Avanti's business case and result in major subsidy increases.
Ah, I see, to go east you first go west at Winwick Junction. Thanks.Well I suppose you could route via Newton-le-Willows?
They used to have one.A link from Stoke to Manchester Airport has been sought for a long time
Somewhat better than when a class 153 used to shuttle up and down the line from Coventry to Stafford. At least people use the Trent Valley local now.I hope the Trent valley locals are happy with their already rammed service becoming even more so!
Excellent idea, but I don't fancy 200 miles on class ;730, from the pics I've seen on Wikipedia they look hard-as-iron seats like Thameslink. Now if they want to replace them with something more comfortable and add an affordable first class section I'd certainly be interested.
Can't disagree with that! If they had an affordable first section, maybe with a few snacks and soft drinks thrown in, might concentrate Avanti to lower their prices for first.The existing units on the Crewe service are a lot more comfortable than the ones on the 730 look.
Assume though they would provide a trolley service for all?
Why bother with that when you could just run a triple 350 and make a 12 car?Might be better to stick the 750's on shorter services and reform some of the 350's into six carriage units so that the Crewe services could be extended to ten carriages.
12 cars of 350 is about equal to a 10 car 730.
The seats are comfortable!Excellent idea, but I don't fancy 200 miles on class ;730, from the pics I've seen on Wikipedia they look hard-as-iron seats like Thameslink. Now if they want to replace them with something more comfortable and add an affordable first class section I'd certainly be interested.
Plan would be to couple and uncouple at Crewe with only 5 carriages carrying on to Manchester. The 5 Car left behind would then be shunted across for the departure 1 hour+ laterCan Manchester Victoria handle 10 car services without any platform works?
The hourly freight slot to Trafford Park is in front of the TfW, isn't it? Not too sure how flexible that is without it sitting at Chelford or hanging back further next Sandbach, which may make it tighter on its path through Styal. I guess platform space might also be tight as you'd get stuck behind the CRE-MAN as that does not arrive to MIA until xx.52, which does not leave much time until the MAN-CRE arrives with a short reversal, and all the platforms are in use by that point.Its not a new idea really. It just about works in the current timetable, the Stafford Crewe can sneak out in front to the TfW to get to the airport, and the Trent Valley will just have to hammer it up to Warrington as the Avanti Glasgow chases it. It will have to likely follow the Class 9 from Warrington going south. The Airport Stafford will likely have to be in front of the Avanti from Manchester.
So adding coupling/uncoupling to a busy station? And terminating service at Victoria in a through platform? What happens to unit at Victoria? Shunt out or stay until its departure?Plan would be to couple and uncouple at Crewe with only 5 carriages carrying on to Manchester. The 5 Car left behind would then be shunted across for the departure 1 hour+ later
As I understand it Northern are to bring back the second Chat Moss stopper from Liverpool extended to Stalybridge.Before this plan sees the actual light of day, I would hope that the following might be in place:-
1. Full implementation by LNW of the 30 minute M-S Liverpool LS - Birmingham New St service;
2. Full power upgrade to allow the second Euston to Lime St service to operate north of Crewe with the new class 807;
3. Transport for the North/Dft/GBR has a clear and agreed plan for the range of regional and local rail services through Manchester, both Victoria and Castlefield corridor so that the best use of the TRU and other infrastructure interventions e.g Victoria turn backs are fully utilised.
I guess if it does happen, the good value 'TfW+LNR' only tickets will disappear with London - Manchester becoming "LNR" only.
Hopefully the seats on the 5 coach 730s are better than the narrow "3-1+2" seating layout of the 3 coach units
How long are the 730’s? 10 cars will be a tight fit at Victoria.Somewhat suprising.
They already need to use one of the thru platforms at Crewe (1, 5, 6, 11, 12) for 10 car 730 services.Path through Castlefield andterminating at Victoria is interesting...
120m so a 10 car would be 240m. I believe only platform 3 (255m) would be long enough.How long are the 730’s? 10 cars will be a tight fit at Victoria.
They have SDO though. Wouldn't be the only station where SDO is used at the origin/terminus.How long are the 730’s? 10 cars will be a tight fit at Victoria.
