Longest electrified stretch fed from one end?
snowball
4 Mar 2013
Where is the longest stretch of electrified track in GB that is normally fed from one end only?
This could be
(1) a stretch from a feeder station to the end of a line
or (2) a stretch from a feeder station to a point where electrification ends and the line continues unelectrified
or (3) a stretch from a feeder station to a track sectioning cabin where the other side is normally fed from a different feeder station.
A "stretch" for the purposes of this question could include parts of more than one line. For example if you want to know where the juice comes from to feed Blackpool North, you have to include, for a start, the whole Preston-Blackpool line, which has no feeder station of its own; but you must then also include also some distance north or south along the WCML to a feeder station. (I imagine Blackpool would normally be fed from Catterall, about 8 miles north of Preston.)
I am sure the third rail one is the substation at Lymington Junction, which feeds the branch all the way to the end at Lymington Pier.
snowball
4 Mar 2013
Of the two third rail examples mentioned so far, Lymington is longer.
Hythe to Clacton and Walton are each less than my example of Caterall to Blackpool. (If you include both Essex branches it might come out about the same, but that wasn't the question.)
Where is King's Lynn fed from?
I suppose autotransformer-fed +-25kV lines should be a separate category from plain 25kV.
InTheEastMids
31 Jan 2016
Isn't the MML as far as Corby currently fed from the new grid supply point near Sundon? That's quite a distance.
I think the GWR main line to Filton is fed from either Melksham or Didcot, although there is a substation at Wooton Bassett. So about 30 miles. From memory, Beyond Filton it is fed from Wales.
AM9
13 May 2014
St Albans
In terms of an individual train at the extremities of those branches, the linear distance from the feed point dominates the impact. In the case of a mini network that is remotely fed, the worst case combination of trains at the ends has a significant effect, e.g. in the peak there could three 2x5car class 720s and single 5car set on the Thorpe-Walton shuttle, that could cause the line voltage to approach the minimum normal level.
Taunton
1 Aug 2013
I seem to remember that when there was an issue at Lymington with the staff member there who had dared to access the track, it was said by management that it was so dangerous because of 750v in the conductor rail. Whereupon more informed staff said you were lucky to get 450v at Lymington.
Kings Lynn?
There’s a feeder at Kings Lynn. However as there are long stretches of single line up there, there is a second 25kV line to keep the other end live in the event of a fault on the OLE over the single track concurrent with an outage at Milton (Cambridge).
McRhu
14 Oct 2015
Lanark
Without wishing to deviate too much... Hypothetically, how far would a 25Kv feed travel through the OLE before it dropped to an unusable voltage? (Or to put it another way, if the WCML was fed from Euston what would the voltage be at Glasgow Central?)
Bristol
That answer rather depends on how much power is being consumed from the system!
At a rough guide, this document suggests feeder substations are required every 50-60km: https://www.bathnes.gov.uk/sites/de...ng/nr_a_guide_to_overhead_electrification.pdf
Various design and system factors would affect this. If you have just a few trains with a light power draw you would get further than if you had lots of trains or trains with high power demand.
DarloRich
Fenny Stratford
I think there is a small feeder at Kings Lynn itself
of course - thank you x 2
AM9
13 May 2014
St Albans
Presumably, auto transformers would be able to extend a long thinly-trafficed line further before the voltage dropped below the working minimum.
Bristol
I'm really no expert, but I suppose that hypothetically if traffic were light enough and sufficient power supplied at the feed point then autotransformers or boosters could keep the voltage within the parameters for a nearly indefinite distance. The laws of physics indicate there must be a limit, but its probably a 'half as much again' situation.
Yes ATs allow more trains within the same length of section, greater distance between feeders for the same number of trains, or a trade-off between the two.
Richard Scott
13 Dec 2018
Under load may drop to 450V but without a load may well be 750V.
450v or 750v DC, either way it will kill you.
Taunton
1 Aug 2013
Not necessarily. Ian Allan, in his autobiography, wrote of more than one Southern employee in WW2 who in the blackout stumbled over the live rail, but was saved by the voltage being generally reduced due to fuel shortage. Not a sure thing, but it can help.
AM9
13 May 2014
St Albans
I doubt the RSS would accept any more 3rd rail on the basis that the voltage sometimes sags below 450V.
Nicholas Lewis
9 Aug 2019
It shouldn't drop below that as CB's should automatically disconnect if voltage drops below 450V. Similarly on old EP stock the no volt relay was set to drop below 450V and that would stop the driver taking power. I guess same parameter is programmed into modern units.
AM9
13 May 2014
St Albans
My comment was about the vain hope that the low voltage is 'safer'. 450V was mentioned by @Taunton as if the staff at Lymington were under the impression that it was safer. Any prolonged contact with a DC voltage over 200V is liable to be lethal.
