At certain times, Plynlimon in the Cambrian Mountains is visible from Mow Cop. The possible panorama from the top of Plynlimon is quite wide-ranging. I am always amazed by what possible extreme vistas can be seen from one spot. With Plynlimon, it is possible in the right conditions to see south-east Ireland in one direction and Derbyshire/Staffordshire/Worcestershire in another direction.
Similar too with the top of Snowdon - being able to see south-east Ireland in one direction and North Yorkshire in another direction.
Plynlimon always strikes me as a 'hidden' upland because I've only ever seen it from very close range, somewhere near Devil's Bridge.
I guess the fact it's a plateau means it's hard to pick out from a distance if there are other large and more prominently-shaped hills in front of it. Never been there but isn't it somewhat reminiscent of parts of Dartmoor (in the sense that it's a plateau rather than a peak)?
Worcestershire Beacon (going back to that again) must be another one - if it is indeed true you can see Kinder Scout from there, and also Uffington White Horse Hill (which I think is true), that makes it perhaps the only place in the UK from which you can see both "northern" and "southern" England (using a definition, admittedly my own, of "the North" beginning at the Dark Peak, as the Dark Peak has that "gritty northern-ness" quite unlike the softer White Peak which to me is Midlands) and "the South" having its northern limit at the Ridgeway path.
