I believe two B5TL’s are being rebranded into the new airlink livery as spares.
Which ones? 496/7?
I believe Airlink replacements are planned for 2025, though in my opinion the current ones could do with an external refresh in the meantime.
I wonder what it’ll be on. Are there any electric chassis that could be used for a tri-axle bus like the E400XLB or MCV Evoseti XL?
I don’t think that E500EVs are available in the UK.
I'd be keeping an eye on Volvo. While there isn't a tri-axle version of the BZL yet, there is a tri-axle BZR in its range; not having a tri-axle, low-floor double decker in the range leaves a significant gap and I suspect it will want to plug that hole eventually. As for bodywork, Alexander Dennis may be unwilling to build, but I'm sure MCV would step in if necessary.
You beat me to it. If Volvo don’t make a tri-axle BZL double-deck chassis before 2025, could a potential tri-axle Yutong bus work if one gets made (what with the first GTe14s being shipped to operators like Ember or the demonstrator used on the Xplore Dundee FLY)?
I think that if they wanted competition, it’d have probably been better to stick to Waterloo Place to get all the passengers at Waverley Steps, & I will stand by that, but I guess that it’s probably just as good, if not better, change competition-wise.
No. There wouldn't be the demand there, plus nowhere to turn a bus.
I always thought a smaller single decker (like a Solo or E200MMC) could turn at one of the small roundabouts on Roman Court, but I’ve just looked at it on street view, & you couldn’t fit anything bigger than a minibus around one of them if you tried.
Eastern Scottish used the northbound lay-by on the A68 around half a mile south of Pathhead to turn buses on their 512? 40 years plus ago.
Yeah, that looks better. Still looks quite narrow for a bus larger than a 9 meter bus to pull out of though.
Part of the Airlink attractiveness is the frequency - its guaranteed it'll turn up especially at later hours. An every 30 minute service won't do that.
Unlike the 26, it doesn't stop at each stop en-route for 3 minutes boarding a number of people. Its faster, especially at peak times, and often allows you to get a seat instead of being cramped stood among other passengers.
The local buses in the area would need peak time frequency boosts to make them more attractive again, in my opinion.
Its a busy service, that's why. Each bus added makes a difference. Less people boarding on each bus will speed up journey times, which are already a bit inconvenient at some stops due to the flow of passengers boarding for the Airport.
I hadn’t really thought that far, but yeah, that’s a fair point. What they could do if they were to make the 100 set down only is increase the X18 to every 20min to make up for it (or, if pressed enough, every 15min).
