norbitonflyer
In Another Place (District Dave) speculation is rife about the recently-announced number range for the new Piccadilly Line stock.
Existing LU stock has 3 digit or 4 digit numbers, or 5 digit numbers in the 1xxxx, 2xxxx, 5xxxx, 6xxxx, and 9xxxx ranges
The new trains will apparently have car numbers in the range 38xxx to 48xxx (each articulated unit will have eleven bodies - I hesitate to call them cars as some will be wheel-less, supported by their neighbours) There seems to be no obvious reason for choosing such a range - why not start at 30xxx?
Although the numbering of S-stock (which runs on NR tracks in places) seems to have avoided the 212xx range simply to avoid duplication with the half dozen surviving Mark 1 BCKs, the Piccadilly Line does not share with NR and in any case the proposed range overlaps with a number of NR types, notably TfL's own Overground Class 378s, whose carriages are numbered in the 38xxx series.
Anyone able to shed light on this?
