LUMO manages Edinburgh to Kings Cross in 3 hr 58 mins!
hexagon789
2 Sep 2016
BR manage 3hr29m29s (I think) with a special 91+5mk4s+dvt set on a special Kings Cross to Edinburgh run. It had special dispensario to run above line speed in many areas up ro 140mph and other services were moved out of its way.
Yes, 3h29m29s - 140 authorised wherever normal linespeed was 125mph.
HST43257
10 Apr 2020
York
Reckon an IET could match 3h29 without the 140 but with the better acceleration away from the likes of London, York, Newcastle and Morpeth?
It could be easily done even faster than that considering the ECML is so straight. Avanti could do Euston to Glasgow in 3hr 52 minutes and that’s on curved track
Curvature is just one of many factors that go into linespeeds and hence journey times.
No chance. If you made sure there were no ESRs or TSRs and got a 100% clear run, you might manage it non-stop in 3h40. At a push.
hexagon789
2 Sep 2016
They are only a minute quicker 0-125 than an IC225.
That's not going to make up nearly 30 mins without exceeding linespeed.
HST43257
10 Apr 2020
York
Yes, there would be the same things about getting services out of the way. Would quicker acceleration not go quite some way to cancelling out the 140mph sections?
23 Jul 2021
Edinburgh
The fastest service in 1988 was the down Flying Scotsman at 4h23.
Sure you aren't thinking of the 3h59 Scottish Pullmans launched after electrification to Edinburgh was completed?
I have obviously got my recollection of holidays mixed up around that time. When did the 06.30 Scottish Pullman EDB/KGX start to operate with a 3hr 59min running time?
Not when you consider the fact that the vast majority of the journey would be undertaken at (or close to) 125mph. Over short distances the extra 15mph makes little difference, but on a non-stop 393 mile run it makes a massive difference.
As a very crude indication, if all 393 miles were done at 125mph, it would take 3h8m. At 140mph, it would take 2h48m. You can accelerate and brake as fast as you want - but it's still not going to save you 20 minutes.
miklcct
2 May 2021
Cricklewood
Of course, but what is being questioned here is *limiting* acceleration. Although if services have to be timetabled to the lowest common denominator there's probably little use for some units behaving differently to others. Other than artificially limiting their ability to make up a little time when running late.
But then, I've long wondered why every train type seemingly has different driving characteristics. Why is this, and controls, not standardised?
Limiting acceleration is useful to prevent a train catching up the one ahead. For example, when the SP1900 train was first deployed on KCR East Rail, because they have better acceleration than the old trains it soon caught behind the one before it, causing uneven frequency.
28 Nov 2021
Leith
Quite possibly not throwing people down the train, or items off tables into people's laps & so on. Fairly sure there's at least one RSSB doc on passenger comfort & acceleration/deceleration levels but I can't remember exactly.
There is a *lot* of publically available engineering data about the 80xs.
Agreed. Any greater acceleration would have them rolling in the aisles, and not in a good way
tornado
6 Apr 2010
But are the WCML and ECML the same length? I believe WCML is 399 miles but could be wrong.
mmh
13 Aug 2016
In the UK that problem is managed with timetables and signals.
The ECML to Edinburgh is slightly shorter than the WCML to Glasgow, at 393 vs 399 miles. That said, Glasgow is further from London (344 vs 332 miles as the crow flies), so the WCML is slightly more direct than the ECML.
hexagon789
2 Sep 2016
Well you only save 1 minute with every full 0-125 acceleration, any acceleration from a rolling speed you're saving seconds. 91s are not bad in the upper speed ranges, it's just the high gearing means they don't get into their stride until about 80mph.
Would be when the full electric timetable to Edinburgh came in during 1991.
Euston to Glasgow is 401.25mi, I don't know where Wikipedia gets its 399 figure from.
400mi43ch, actually. I guess with rounding and change of mileages it's easy to lose a mile somewhere along the line.
Having taken another look at the changes of mileage, I stand corrected and it's actually 401mi32ch:
Euston
0mi0ch
Warrington South Jn
181mi74ch -> 181mi76ch
Golborne Jn
187mi76ch -> 0mi53ch
Preston
21mi57ch -> 0mi0ch
Lancaster
20mi78ch -> 0mi0ch
Carlisle
69mi9ch -> 0mi0ch
Glasgow Central
102mi27ch
Total 401mi32ch
miklcct
2 May 2021
Cricklewood
But if the timetable is squeezed into the limit and you want more trains per hour, you will need measures such as automatic train operation, signalling upgrade, etc.
Sean Emmett
9 Mar 2015
Euston
0mi0ch
Warrington South Jn
Golborne Jn
Preston
21mi57ch -> 0mi0ch
Lancaster
20mi78ch -> 0mi0ch
Carlisle
69mi9ch -> 0mi0ch
Glasgow Central
102mi27ch
Total 401mi32ch
Yes, but IIRC the electrification survey showed the line between Carlisle and Glasgow is approx 11 chains longer than posted.
But then deduct the length of the train and it's as you were...
Indeed; the posted mileages are really more approximations, given that they were done, by hand, back in the 19th Century...!
