Usually I stick to the bus side of the forum, this is my first post on the rail side.
I am travelling to Manchester in April and intend on having a day out in Liverpool, having first done the requisite bus-related things in Eccles and at the Trafford Centre. I will be in GM for the week on a System One (Bus + Train) week ticket, and therein lies the basis for my questions.
1. If I travel using the Eccles line in both directions, can I 'get away' with a System one card and a Merseyside savaway (Day) ticket? Essentially, do the ticketing boundaries go right up to the boundaries, thus allowing me to travel beyond Patricroft on System One, or will I find myself having to do something silly like buy a ticket between Patricroft and Newton-le-Willows? I know this won't work with the Urmston Line as I cross through Warrington... or will it?
2. If I wanted to make sure I could travel back by either line (to take advantage of the faster trains, which all seem to run on the Warrington/Urmston line), does a standard Manchester - Liverpool return (even if I buy it at Eccles) cover both lines, or are they only available via one or the other line?
3. Just double-checking - National Rail being what it is - there is no benefit to only booking as far as Oxford Road, as supposed to Piccadilly.
4. More double checking: Is it possible to buy a savaway outside the Merseytravel area (i.e. Eccles or Urmston)?
5. Finally, unless I'm being dim, I can't find a map of the savaway area that is as detailed as that for Manchester. What would be the last station such a ticket would be valid on on the Warrington line? (And is it actually worth a three-ticket extravaganza?)
Many Thanks!
Many Thanks!
