Since the EML opened every Shaw tram runs into the Rochdale bound through platform at Shaw where they empty and run to Rochdale ghosting. They then come back and pick up at Shaw.
Thank you
Would this even apply during the peaks, for instance?
Thank you
Went on both the Droylsden and Rochdale extensions today and found them quite slow (compared to the Bury line), is this due to bedding in of the track?
Droylsden in particular will always be slower than the Bury line; it's either street running and limited to 30mph (compared to 50 on the Bury) and the segregated bits are generally too twisty to get up much speed.
whats patronage like on ORL2? From SCC photos it looks quite busy even off peak?
I believe Shaw-Rochdale was singled in the early 1970s but I'm not 100% certain.
Just seen another gr8 video on the scc forum it covers the new line from oldham 2 rochdale....Check it out guys..
http://www.youtube.com/watch?v=BtxiwNQc63s
Brings back plenty of memories.
Did the Rochdale extension yesterday evening (after a day at the East Lancs).
Journey times appears to be longer than what it says on the information posters, it took about 40 minutes to/from Victoria, although posters on the platforms at St Peters Square and Market Street were quoting journey times of just over 30 minutes.
Weird, the metrolink website gives it as 45 minutes!
Metrolink said:St Werburghs Road Rochdale Railway Station 70 minutes
St Werburghs Road Victoria, approximate journey time 25 minutes.
Rochdale Railway Station Victoria, approximate journey time 45 minutes
The points that have failed are probably the ones on the single line section at Newton Heath. They're very unreliable as they're sprung or too heavy idk technicalities...
There was a points problem at Newbold on Saturday which led to no trains between Oldham and Rochdale for a couple of hours. Services resumed with delays with the points being changed manually with hand signalling.
