Manchester Piccadilly to cancel trains for roof repairs
All trains from Manchester Piccadilly are to be cancelled on Sunday, Network Rail says.
www.bbc.co.uk
I wasn't aware of this; National Rail Enquiries saysAll trains from Manchester Piccadilly are to be cancelled on Sunday, Network Rail have announced.
Trains are to be replaced by buses on Sunday "due to engineering works on our train shed roof", it tweeted.
Network Rail which owns and manages Manchester Piccadilly station thanked passengers for their patience ahead of the engineering works.
Manchester Piccadilly was the 10th busiest railway station in Britain between 1 April 2021 and 31 March 2022.
Does anyone have more information on the work taking place at Manchester Piccadilly or is it just something like regular maintenance over the entire roof which affects all platforms potentially so the station's closed as a precaution. Why are platforms 13 & 14 closed also, or are they currently still closed for other reasons?Start date15/01/2023End date15/01/2023Route affected
All routes via Stockport
Train operators affectedAvanti West Coast , CrossCountry , Northern , TransPennine Express , Transport for WalesDescription
Engineering work is taking place between Stockport and Manchester Piccadilly, closing some lines.
Avanti West Coast:
Buses will replace trains between Manchester Piccadilly and Stockport.
CrossCountry:
Buses replace trains between Stockport and Manchester Piccadilly.
Northern:
Trains that run between Manchester Piccadilly and Crewe / Buxton / Chester will start / terminate at Stockport. A rail replacement bus service will be in operation between Manchester Piccadilly and Stockport.
Trains that run between Manchester Piccadilly and Manchester Airport will be replaced by a bus throughout.
TransPennine Express:
There will be no service between Manchester Airport and Manchester Piccadilly.
Additionally Manchester Piccadilly will be closed all day. All services will be diverted to start / terminate at Manchester Victoria.
Services between Glasgow Central / Edinburgh and Manchester Airport will be diverted to start / terminate at Preston.
A rail replacement bus service will be in operation between Manchester Airport and Manchester Piccadilly / Preston.
Transport for Wales:
Buses will replace trains between Crewe / Warrington Bank Quay and Manchester Piccadilly.
Check before you travel:
You can plan your journey using the National Rail Enquiries Journey Planner
Replacement Bus Travel Advice:
For helpful advice if you need to travel on a rail replacement service, including accessibility and bicycle information, please use this page.
You can find the location of your bus replacement by checking station signs or by searching for your station on our station information pages.
