Rheoman
Taken 16 years ago on a state of the art Sony 1.3mp camera phone approaching Linslade tunnels- before the mobile phone ban came in!That’s a brave profile picture!
It'll work fine if you stand in one of the vestibules.I have to say that whenever I've tried to use my GPS on a Pendolino it's simply refused to work so I can believe there can be issues!
I suspect that the train will have a large, fixed, probably external, antenna.If the speed limiter in modern trains is based off GPS that would seem to indicate that it's accurate enough.
they had them fancy modern electric trains. @43066 suggests he done it a 1970's lump powered by a submarine engine! Winner.
OFFICAL ANNOUCEMENT: In no way does RUK encourage or support such dangerous risk taking. It is not big, it isn't clever and it costs a fortune in diesel and lubrication oil.
The Deltic engine was developed to meet the need identified by the Admiralty for a high-powered, lightweight diesel engine for fast patrol boats. The Second World War had demonstrated vulnerabilities in using petrol engines, most notably flammability.
The Deltic is a two-stroke opposed-piston compression ignition diesel engine with either three or six banks of three cylinders arranged in a triangle. Crankshafts are located at each corner of the triangle with each crank having an exhaust and inlet connecting rod from the two adjacent cylinders. The crankshafts were connected by phasing gears to a single output shaft.
The first engine was produced in 1950. The Deltic went on to power many of the Royal Navy’s small and fast craft and was still in use in Hunt-class vessels in 2018. The Deltic was primarily used at sea, but it was also used in some British Rail locomotives.
Would that be a reference to the Deltic engine's naval origins
It was also used in various surface ships: most notably in Type 23 frigates (four in each) and eight in each of the three Invincible class aircraft carriers (which also had four Olympus gas turbines).No - the Paxman Valenta was used in, I think, the RN Upholder class submarine. They were all sold to the Canadian Navy and are now called something else. They were the last RN diesel submarines.
Thanks - I knew the Invincible class carriers had the Olympus gas turbines but not the rest. Interesting.It was also used in various surface ships: most notably in Type 23 frigates (four in each) and eight in each of the three Invincible class aircraft carriers (which also had four Olympus gas turbines).
What I don’t know is if the ships had the Napier turbocharger: you’d suspect not!!!Thanks - I knew the Invincible class carriers had the Olympus gas turbines but not the rest. Interesting.
PS the Soviets must have had bad sonar not to hear an HST coming towards them underwater
Fascinating stuff guys, but we're going wildly OT here! In an attempt to rectify this, I would like to point out that 124 mph is nearer to the metric speed of 200 km/h....so it will probably become the new norm when ETCS is rolled out.Thanks - I knew the Invincible class carriers had the Olympus gas turbines but not the rest. Interesting.
Thanks for the correction. Wow, I remember the Upholder class being the future patrol subs - I had no idea they had had such a short RN service life. Nor did I have any idea that the Valenta went underwater!No - the Paxman Valenta was used in, I think, the RN Upholder class submarine. They were all sold to the Canadian Navy and are now called something else. They were the last RN diesel submarines.
The Deltic engine went in the RN Hunt class of minesweeper but they have been replaced by CAT engines now.
