thealexweb
- Joined
- 5 Jan 2014
- Messages
- 1,051
What website are you using to see these? The trains currently in the system are the trains that will NOT be running in May 2018 and are merely holding paths. How can you see what the headcodes are, I am using Open Train Times and I can just see the headcodes as "FRGT".
Adam![]()
This was at the agreement of St. Helens Council, Merseytravel and TPE. It is no secret that the parking facilities and public transport at Junction are woeful and St. Helens Council/Network Rail have been struggling to come up with a solution to the overflow onto street parking around Junction. Whilst I agree that the waiting facilities at Junction are significantly better currently, the 'express' TPE stopping there might be the incentive required to improve facilities at Lea Green, which is likely to be a lot easier than at Junction without the heritage issues and with both land and height to work. So I am mildly optimistic about this solution, and only await a name change from Lea Green to St. Helens South.
Sorry, the headcodes are in TRUST. I checked both sources and I thought headcodes were shown in both.
I can't see why these trains wouldn't be running. What makes you say that?
Manchester Airport-Stalybridge appears to be 3 minutes slower via the Ordsall Curve than by reversing across the layout at Piccadilly via Guide Bridge.
Two extra stops of course, at Oxford Road and Victoria.
Is that what was anticipated?
I don't want to seem rude, but I work for them and have seen the staff brief. I am unsure of what I am allowed to share hence why I am acting somewhat aloof. The trains shown are the ones that aren't running, hence there are trains terminating at Blackfriars from the North. The WGC trains will run to Sevenoaks, but only from December 2019. Check the operator code, they are ZZ.
Adam![]()
Fine, but you're not the only one who works for them. As I said, TRUST shows these trains (when I checked a week ago they were not there). I cannot see why so many trains would be in the system if they weren't genuine.
The trains I saw today are Cambridge-Brighton/Maidstone/Ashford. None are shown terminating at Blackfriars and all are shown with class 9 headcodes.
I find it hard to believe that journeys from Manchester Piccadilly to Leeds will be able to gain 15 minutes through line speed improvements over the next year or so? There are a large number of journeys at 49 min at present but many seem to be increasing to 63 or 64 mins on indicative timings.The objective is to avoid conflicting movements at Piccadilly and subsequent delays. The journey will speed up over the next year or so via linespeed improvements.
The end plan by 2020 is that TPE will take 40 mins from Man Vic (so 50-52 from Picc) to Leeds
Some journeys for May in Open Train Times ( usual caveate applied )achieve less than 49 from LDS to MCV
Could all be moot now until December 2018. http://www.theboltonnews.co.uk/news...ugh_Bolton_delayed_by_a_further_SEVEN_months/
This shouldn't affect TPE much
There are a significant number of Northern changes penciled in for May 2018 which are a direct result of North TPE e.g. running a Liverpool-Warrington-Manchester Airport service to plug the gap left by the Scarborough service switching to Chat Moss and also indirect e.g. the times of pretty much all the southbound services out of Piccadilly changing.
@BMIFlyer That's good to know. Both the Barrow/Windermere's and Scotlands have run via Wigan in the past (with both stopping, in fact) so there's certainly capacity, subject to other changes and as you say the pathing constraints to/from the airport and through castlefield.Yes that is correct but I have been informed today that the majority of changes at TPE won't be affected and will still happen. The major issues are the timings of the Man Air to Scotland trains as they might now have to run via Wigan non stop instead of Bolton non stop/pickup/set down only.
The movement of all Liverpool TPE trains to Chat Moss should still happen. Can't see why it won't.
Given the extra stops I think that's pretty good actually!Manchester Airport-Stalybridge appears to be 3 minutes slower via the Ordsall Curve than by reversing across the layout at Piccadilly via Guide Bridge.
They were aiming for 90 secs max dwell time at Piccadilly 13/14 were they not? That would explain it if so.Presumably the time the unit sits at Piccadilly has been reduced significantly as Piccadilly to Huddersfield takes significantly longer via the Ordsall Chord than via Guide Bridge.
I think what jcollins was referring to was the reason why this change has already been delayed - the lack of Northern units to replace the service.Can't see why it won't.
However, given that it is being downgraded to a 75mph it could be possible to find something to resource it.
The Stockport-Stalybridge train is moving to Saturday at 09:45
More XC services calling at Macclesfield.Anything @ Stafford?
Open Train Times seems to also show several peak hour trains stopping at Guide Bride and Stalybridge then stops to Huddersfield. Hope these stops lastXC appear to be increasing calls at Macclesfield with the Manchester-Bristol services calling on most if not all trains now.
