Poking around on realtimetrains (which I have recently discovered) I have found what looks like an inconsistency and I do not understand it.
1M07 from WOS terminates BHM platform 11b at 1644. The "Schedule Information" field has "WTT schedule UID P83409, identity 1M07; Runs SO between 26/05/2018 to 08/12/2018; Service code 22329000". The "Operational Information" field says "Pathed as Class 158 (Express Sprinter) DMU".
1V21 to HFD departs BHM platform 11b at 1650. The "Schedule Information" field has "WTT schedule UID P83427, identity 1V21; Runs SO between 26/05/2018 to 08/12/2018; Service code 22329000". The "Operational Information" field says "Pathed as Class 150/153/155/156 (Sprinter) DMU".
Looking at what goes on at BHM around those times, there is nothing else, either in service or ECS, using platform 11 between 1V12, which comes in one end and goes out the other, and 1M07/1V21. The only stock to have arrived and remained at platform 11b before 1V21 departs is the terminating 1M07; and with only 6 minutes to do it in, it doesn't seem possible that one lot of stock can go out ECS and another lot come in and RTT just doesn't show it because it's too trivial or something. Therefore, the two services must be composed of the identical vehicles.
So how is it that 1M07 is "Pathed as Class 158", and 1V21 is "Pathed as Class 150/153/155/156"?
And then the same thing happens in reverse at HFD - 1V21's stock is sitting in platform 1 waiting to go back out as 2C71, then there is a twangy noise and a puff of coloured smoke, and it turns back into a 158. I don't understand this either.
