Qwerty133
Considering they are currently suffering from major stock shortages to the extent of cancelling services EMT should not be lending out any stock.
Which services are they cancelling?How impressive. Shame they are cancelling their own services due to a lack of stock being in the right place.
Various local services. Also been a couple of London services cancelled in the last week.Which services are they cancelling?
How does an HST set at Cricklewood between the peaks help with running local services? It doesn't, doubly so when there only a limited number of local crews that sign HSTs.Various local services. Also been a couple of London services cancelled in the last week.
Even last Sunday (when they were running only half the normal service level) multiple trains were short formed to the extent of leaving people behind.
Ending the hire out reduces the milage and could quite possibly give each HST an extra day in service between services giving higher availability for their own services including the diagram that seems to be replaced by a 4 coach 222 more often than not including on days where the 222 is meant to be working local services.How does an HST set at Cricklewood between the peaks help with running local services? It doesn't, doubly so when there only a limited number of local crews that sign HSTs.
I think you are rather clutching at straws by using words like "could" and "possibly". EMT HST maintenance is planned round a rotation of sets where the heavier maintenance is done when the set is stopped for a week-long exam. So at any one time, from the nine sets there will be 8 in traffic and one on the exam for the week. Hiring the set out does not affect that cycle.Ending the hire out reduces the milage and could quite possibly give each HST an extra day in service between services giving higher availability for their own services including the diagram that seems to be replaced by a 4 coach 222 more often than not including on days where the 222 is meant to be working local services.
I can only assume that you are ignoring the fact that the EMT HSTs are currently failing at a rate that means at least one HST diagram needs to be covered by a 222 most days?I think you are rather clutching at straws by using words like "could" and "possibly". EMT HST maintenance is planned round a rotation of sets where the heavier maintenance is done when the set is stopped for a week-long exam. So at any one time, from the nine sets there will be 8 in traffic and one on the exam for the week. Hiring the set out does not affect that cycle.
The bottom line is that EMT are not hiring sets out to the detriment of their own services.
The problem on a Sunday for EMT is that only the HSTS and 5 coach meridians are suitable for use as 4 standard class coaches is far from sufficient on any service. Why on earth the 7 coach 222s still have 3 coaches of first for an average occupancy of 3 outside of peak times (unless its one of the few services offering cheap advances) is beyond me.
Best just leave the trains sat on the depot and never use them! They'll never fail then.Otherwise you are suggesting that additional milage doesn't increase the probability of a unit failing which is complete nonsense. EMT simply do not have the capacity to allow their units to do anything that increases the probability of them needing unplanned maintenance which the hire-out unquestionably does (especially as it requires the units to do sustained periods of 125 running something that the units have never had to do in over 30 years in service).
I think there's a reduced service on the MML today with trains using the slow lines Kettering-Bedford hence being able to hire an extra set to LNER for a Leeds-Edinburgh-Kings Cross-Lincoln diagram.
No it's the usual Sunday timetable! The reduced service on Sundays means that the Meridians don't have enough seating capacity, hence why EMT use all of their HSTs on a Sunday
Having checked there is a vastly reduced service on the MML today. Wellingborough to Bedford fast lines are under possession and a reduced service operating via the slow lines. The normal 4 trains an hour to/from St Pancras that normally operates from mid afternoon has been reduced by over 50% to just 2 an hour or less with some 75+minute gaps. The morning service was also reduced from 2 an hour to just 1 an hour.
And even half of what was meant to run didn't due to various faults leaving trains out of place...Having checked there is a vastly reduced service on the MML today. Wellingborough to Bedford fast lines are under possession and a reduced service operating via the slow lines. The normal 4 trains an hour to/from St Pancras that normally operates from mid afternoon has been reduced by over 50% to just 2 an hour or less with some 75+minute gaps. The morning service was also reduced from 2 an hour to just 1 an hour.
