Network Rail recruitment question
Amanda
5 Mar 2018
I've applied for a role with Network Rail for which, on reflection, I think I should have submitted a covering letter. The closing date hasn't passed yet.
Is there a way to add it retrospectively?
OR
If I withdraw my application can I apply again for the same job reference number (and include it on the new application) ?
Chumba
13 May 2019
OR
you can just upload it to the document section there’s a drop down if I recall to type of document. I changed my CV last application, just deleted the current one and uploaded a new one.
Stigy
6 Nov 2009
OR
Unless it’s changed, you should be able to log in to your portal thingy and add files?
Amanda
5 Mar 2018
Okay so my question now is, if I add a document will it show for all applications, or will it only be available to new applications? I have found the button to upload a file but it only seems to be on my profile rather than the application I wanted to add the document to.
Chumba
13 May 2019
yes it’s in your profile and is used for all applications, saves you having to change them every time you apply
