Journeyman
- Joined
- 16 Apr 2014
- Messages
- 6,295
I'm spinning this off from the thoughts about steam thread, where it was suggested Mark 1 lookalikes could be built for charter use. Given that there are quite a few charter vehicles knocking about, and that the Mark 1 isn't going to last forever, I did wonder if it would be possible to draw up a spec for new build coaches. If there was enough agreement across the board, I don't see why it wouldn't be possible for a suitably large build to go ahead. There's probably a lot of obstacles, but let's dream big, eh?!?
I think a lot of people agree that the ambience and atmosphere of a Mark 1 is perfect for steam tours especially, although an exact recreation of that would be fraught with difficulty. However, if you use getting as close as possible to that as a starting point, maybe you can start drawing up some specs. First off, let's look at the technical stuff. You would need...
For catering, guards accommodation etc, it would probably be possible to use existing vehicles, so I doubt you'd have to build new ones. Mark 3 catering vehicles are pretty capable, for example.
Given that CAF were willing to open a production line for 75 highly specialised sleeper vehicles, and Stadler would probably do it for even fewer, it could just about be feasible.
What do we all think? Is it a go-er, or should I put the crayons away?
- Fully integral construction to meet modern crashworthiness standards
- Power doors
- Accessibility legislation compliance to at least a certain level - it might be possible to get around some aspects of it if the stock isn't intended for scheduled service, like contrasting doors, but the rest should be included, so wheelchair spaces, accessible toilets etc.
- I'd suggest dual brakes and dual heat. Fit aircon, but provide (lockable) opening windows so they can be used on enthusiast-oriented services where this would be popular.
- I'd also suggest keeping things as simple as possible. Provide as much backwards compatibility as possible with older coaches, don't provide complex stuff like on-board computers or train management systems, and it might even be possible to recondition older bogies - BT10s, or even B4s and B5s, would provide perfectly adequate and safe ride qualities.
