They'll all be detachable in depot for maintenance purposes, but not when units are coupled and uncoupled in service.Well 25kV lines are still detachable in the case of TGV power cars.
Post #21what context are you referring to 2-car EMUs (like 456s and 466s) in...?
ah yes, thanks!Post #21
A new design for an EMU family could easily make provision for alternative power sources to feed the DC bus, diesel genset or batteries, (or even both) just need to be connected onto that bus. The traction control and motor drives are then operating in the same way except that under regeneration conditions where kinetic energy in the moving train is converted back to electrical energy, it is then:
1) fed back through the transformer to the OLEA well designed DEMU, whilst wasting energy and probably carrying slightly more weight than a diesel mechanical MU, should make better use of the diesel engine's power curve to give better fuel economy, and have lower maintenance costs.
2) fed through tbe collector shoes directly to the 3rd rail
3) used to charge the batteries
4) or wasted as heat in resistor banks on a pure DEMU train.
Come to think of it, Electrostars have driving vehicles barely over 20m long and the class 195 driving vehicles are (I think) 24m long so even if the pantograph was at the inner-end of the driving vehicle the seperation wouldn't be that much less (or maybe even the same) than a worst-case pair of Electrostars.Yes that's a possibility - the separation would be as good as a pair of standard 4-car EMUs in the worst case orientiation, which as far as I know are unrestricted up to at least 100mph. I guess the problem would be finding the space for all the cab equipment if that part has a flat roof.
which makes me wonder whether there are any restrictions on pantograph spacing for operation at 100mph or less. Above 100mph there are probably issues, but are there any rules regarding multiple pantographs at lower speeds?At lower freight speeds 2 pantographs close together won't be an issue see the 86 pairs every day!
Although the 86s are or were 100mph locomotives, the trains they haul are 75mph maximum and the locos may even have been downgraded to that speed. So if there was a restriction of two pantographs to 75mph it wouldn't affect them significantly.And then I came across this in the class 91s to Europhenix topic:which makes me wonder whether there are any restrictions on pantograph spacing for operation at 100mph or less. Above 100mph there are probably issues, but are there any rules regarding multiple pantographs at lower speeds?
Ah, so they don't go above 75mph when running in pairs.Although the 86s are or were 100mph locomotives, the trains they haul are 75mph maximum and the locos may even have been downgraded to that speed. So if there was a restriction of two pantographs to 75mph it wouldn't affect them significantly.
If you think 195s are bad, Transport for Wales have slightly more vehicles on-order from CAF than Northern ordered and they have also gone for DMU not DEMU as far as I'm aware.The real boon is that DEMUs can have a life beyond the electrification of their lines whereas DMUs are a technology cul-de-sac. It's a ashame that the climate change debate took hold after the 195s were ordered, because there must be regrets that pure diesels were bought.
This makes so much sense, it's such a shame that we must 'never assume that railways are rational organisations' and have ended up with the diesel-future class 195/196 and likely TfW's units too unless somebody gets the message and acts quickly to bang in a variation order. Now, who would have the authority to do that...The 195s are DMUs pure and simple, -they have diesel engines, mechanical or hydraulic transmission and mechanical drives to the axles. To convert them to bi-mode or even plain EMU would require a complete rebuild so probably not worth the effort. If they were built as DEMUs with passive provision to convert to a full bi-mode EDMU*, (or even a normal EMU), conversion would enable the bogies, and much of the electric infrastructure to be utilised. Indeed if a new design MU was to be created that had provision for all viable roles, the removal of diesel-powered units from UK railways could be managed a lot smoother and probably with lower total costs.
Wales is getting a short stretch of wires (Cardiff - Severn tunnel) soon, but other than that you are correct to say that Wales isn't getting wires soon. However, there is talk of extending electrification from Wolverhampton to Shrewsbury, which is a route covered by Wales & Borders services and services to Liverpool and Manchester also run under the wires. The Welsh Government has also attempted to get electrification of the north Wales coast line - DEMUs with passive provision for convertion to bi-mode (if such a thing is possible) would help make the case for that. If they are serious about getting the north Wales coast wired, buying new DMUs is shooting themselves in the foot.They're probably less of an issue for Wales, as Wales isn't going to get the wires any time soon and other power methods are nowhere near ready. It's the Northern order that was an error to the point of gross negligence - Northern ordered them knowing they would be spewing fumes under the wires.
Therein lies the problem! Just because an ideological obsession with privatisation, competition and 'choice?' has fragmented the railway into little profit fiefdoms where decisions are made purely on a short-term profit culture, doesn't mean that all of those operations should operate in their own vacuums. Rolling stock procurement is presided over by the DfT, - either directly in terms of authorising and funding through subsidies, or indirectly by awarding franchises/management contracts on the basis of bids that include specific rolling stock acquisitions. In terms of subsidies, we are here talking about franchises that are among the most heavily subsidised so their control is absolute if they chose to exercise it.They're probably less of an issue for Wales, as Wales isn't going to get the wires any time soon and other power methods are nowhere near ready. It's the Northern order that was an error to the point of gross negligence - Northern ordered them knowing they would be spewing fumes under the wires.
Because such things are communist.One thing that's quite interesting is that the Class 80x is very similar to an old style BR standardisation - it has basically, with only the odd exception, become the new standard IC train. Yet there hasn't been a regional equivalent. Why, I wonder?
One of the reasons that we have this situation is that even where a single procuring authority is involved, each purchase is judged on its compliance to an inadequate spec., and all that's left is to then declare the lowest price offer as the winner. A clear case of not knowing how to procure in a competitive environment.Because such things are communist.
The Government and wider industry has bought the manufacturers lies about "software can't be made compatible" and allow them to insist on the use of lock-in prone proprietary solutions for everything.
So we end up with a zoo of train types rather than Networker/Sprinter - where trains are compatible even if they are from different builders.
And even the Networkers were wiring compatible with most Mark 3 EMUs, or very nearly so.
However another part of privatization was to make trains leased rather than owned by a franchise, so they are able to move elsewhere at the end of the franchise term. Partly as a consequence, manufacturers and leasing companies have developed go-anywhere designs for regional units, which are able to be leased to different operators without major modifications. This is unlike the latter days of BR, when Network SouthEast ordered the 165/166 fleet whose dimensions limited it to a small part of the network and whose couplers were (apparently) deliberately modified to be incompatible with the technically similar units in the Regional fleet.Therein lies the problem! Just because an ideological obsession with privatisation, competition and 'choice?' has fragmented the railway into little profit fiefdoms where decisions are made purely on a short-term profit culture, doesn't mean that all of those operations should operate in their own vacuums. Rolling stock procurement is presided over by the DfT, - either directly in terms of authorising and funding through subsidies, or indirectly by awarding franchises/management contracts on the basis of bids that include specific rolling stock acquisitions. In terms of subsidies, we are here talking about franchises that are among the most heavily subsidised so their control is absolute if they chose to exercise it.
It's unlikely the 15x fleet will last more than another decade and the DMUs built in the early privatization years are only 10 years or so younger. The Civity fleets currently being introduced could fill all these roles, possibly with some interior refits. So the question is more about the tradeoff between passenger growth, electrification and development of other self-powered technologies which determines how many Civity units will have a long-term role replacing other diesels.
Not just incompetence, having 2-car units might match the requirement that they are intended for, but when other lines have a shortfall, the temptation to undersupply them with shorter trains is all too much. If a uniform 3-car fleet was used, it would be easier to manage demand in times of disruption.And I believe that is the reason why 2-car units were ordered - with the best will in the world, Ormskirk-Preston or Kirkby-Wigan (say) is unlikely to justify a 3-car set any time soon.
It's just Northern's incompetence that has led to these running alone on the mainline.
There are standard plugs and sockets for feeding auxiliary supplies through a train. 25kV or 750V traction supplies can be fed through a bus wire within a unit not to or from other units coupled to it.
The only example I can think of where traction power is transferred via a plug and socket is the "slug" units in the US, which are (or were) "locomotives" with traction motors but no engine, plugged in to an actual locomotive and taking power from it to increase tractive effort at low speeds. I don't know the voltage used but it would be in the hundreds of volts as supplied to the motors, certainly not 25kV. In principle something like that might be possible with the "DC Link" in a modern traction package, but highly likely to be a manual plug and socket not through an autocoupler.
Driving trailers? All of the Blue Pullman driving vehicles were power cars, similar to HST operation, fitted with 1000hp MAN engines.How was the power transferred to the driving trailers in the Blue Pullmans?
I should have said non-driving motorDriving trailers? All of the Blue Pullman driving vehicles were power cars, similar to HST operation, fitted with 1000hp MAN engines.
Ah right, I wondered if I'd missed some nuance there, my apologies. The only source I have to hand only states that power for the motor bogie was transferred "through cables", which is less than enlightening!I should have said non-driving motor
the "trailer" next to the power car had a motor bogie
There would have been some sort of plug and socket similar to the "slugs" I mentioned, at traction motor voltage. Certainly not an autocoupler.How was the power transferred to the driving trailers in the Blue Pullmans?
The obvious solution is to have a completely uniform 3-car fleet and then just cut fares on Ormsirk-Preston and Kirkby-Wigan to improve patronage.
Iarnród Éireann orders Stage V MTU PowerPacks
IRELAND: Rolls-Royce has been awarded a contract to supply 41 ‘hybrid-ready’ MTU PowerPacks for the additional Class 22000 inter-city diesel multiple-unit cars which Iarnród Éireann ordered from Mitsui & Co last year.
These PowerPacks will be fitted with MTU 6H 1800 R86 diesel engines complying with EU Stage V emissions regulations.
Delivery is to commence in 2021, with the PowerPacks to be in service from late 2022. They will have provision for the future installation of batteries, subject to the outcome of testing which is scheduled to begin in 2021.
Exactly.The fuel burn of the railway is rather small compared to other sectors of the economy.
IIRC the railway uses about 530kT of fuel oil per annum, the airline industry uses something like 15,000kT.
Hahahahahahahahahah 2050. Fat chance.I believe the Rail Industry Decarbonisation Task Force has recomended a net zero by 2050 target for the rail industry, and have also supported the withdrawal of all diesel-only trains by 2040.
However, construction of new trains involves a not insignificant amount of carbon emmisions (eg. in the smelting of aluminium) so it is prudent to maximise the viable working life of trains so that they are not replaced too often. Give Northern's class 195s a 30 year life and they'd be withdrawn in... 2049-2050. Would building a new fleet to replace them in 2040 cause more emmisions than allowing the 195s to run until 2050? The class 196 and Wales & Borders fleets, given that they are not yet even under construction as far as I know, could still be with us in the 2050s.
I doubt most passengers even notice.You can have all the stats you like but the ordinary bod on the street is going to hear “green trains” but be thinking “that noisy, rattly, thing belching out fumes in my local station?”
Yeah, that is strange. Better to have a ton of disjointed incompatible fleets I guess...One thing that's quite interesting is that the Class 80x is very similar to an old style BR standardisation - it has basically, with only the odd exception, become the new standard IC train. Yet there hasn't been a regional equivalent. Why, I wonder?
Yeah lol, that sounds about right.Because such things are communist.
Yes. The MTU PowerPacks used by the Civitys have this available, it shouldn't be hard to fit.Could the later builds of 19x (really meaning the Welsh 197s) have their orders modified to 'hybrid ready' power packs like these ones for the new cars ordered by Iarnród Éireann to lengthen their trains?
