JohnB57
Can we call it "Livermanleedersfield"?If the 'agglomeration' theory is correct then it is a question of needing to create a linear city!
But it should have something to do with HS2. HS2 is supposedly going to be a part of the National Rail Network, with 'Network' being the operative term. Also, it's not as if the current trans-Pennine corridors couldn't do with some capacity relief. Many of the Northern Rail commuter lines could have service levels more akin to Merseyrail. Worse than a shot in the arm. Also, if it does happen, I envisage any new approach into Liverpool being shared with HS2, as per Greengauge21's proposals a few years ago, so they would be linked.
I tend to agree, the original route of HS2 to Manchester Airport and Manchester city centre provides little benefit for the rest of North West England as a whole.
And faster trains to Knutsford?
The engineering problems aren't that hard to overcome are they? Admittedly hard to move platforms west of the Pennines but perhaps a dynamic loop to let stoppers past?
Standege east portal slew the tracks across the alignment, through lines at Marsden and Slaithwaite, a bit more slewing through Heaton Lodge perhaps to take both TPE tracks underneath. Move Ravensthorpe platforms onto a new slow line to the south, realign the platforms at Batley to create through lines. Tilting EMUs, mega scenery, could be a quick blast.
Sent from my Nexus 7 using Tapatalk
Has anyone seen what speed improvements are planned for Manchester to Leeds with electrification? What has been done between Liverpool and Manchester seems rather disappointing and it would be a pity if as little was done further east.
The problem of the time lost with the very low speed layouts at Liverpool, Manchester, and Leeds will never now be solved, but surely more could be done to raise running speeds between Manchester and Leeds -- remember how the old Eastern Region got much of the Marsden to Huddersfield line up to 80/85 years ago and did quite a lot further east whilst the LMR did nothing west of the Pennines. And note how Stalybridge has just been re-designed for nice low speeds to and from Victoria just as the principal service is to be diverted to that station.
'Creaking' would seem to be a popular current media term for 'old, tired and unable to keep up', which is simply incorrect here. Usual case of journalistic emebellishment (or 'bullsh*t') as most of us might call it.
Manchester - Toton - Leeds?
But, getting into the spirit of the forum where anything is possible, nay easy and cost is irrelevant, here's the solution.How did the Eastern Region get the speeds up between Huddersfield and Marsden? By slewing double track across a four-track formation. Where exactly is the four-track formation to do the same on the other side from Stalybridge to Diggle? That's right, there isn't one...
The only minor obstacles to this are a couple of filled in tunnels, a missing viaduct, a handful of housing estates and some industrial units....
I know you like your smilies Paul, but there isn't one for "tongue in cheek"! I'll try to be more obvious in future.It is always good to actually know of what matters are like "on the ground" are really like when "fantasy" projects are put forward...:roll:
Rebuild the Micklehurst Loop as single line and then single the existing line, running Manchester bound over the rebuilt line, with Huddersfield bound as now. That would allow you to slew the line over the current formation and maybe gain a few precious miles per hour. The only minor obstacles to this are a couple of filled in tunnels, a missing viaduct, a handful of housing estates and some industrial units. Also, there'd be a massive opportunity for an additional "Greenfield Lower" station, Tyndrum style (Gangnam Style in kilts?), separated from "Upper Greenfield" by a short half kilometre walk. You could have a booking office in Tesco that would be conveniently located half way between the two. Minimal cost, and a massive time saving - possibly up to a minute or so - for rail travel o'er t' top.
Titter ye may, but there are plenty of dafter suggestions on here...
How would going the 'long' way round VIA HS2 work, ie; Manchester - Toton - Leeds? Could the high speeds give a good journey time? Or would there even be other benefits too?
And I thought I had displayed as many flags as possible!I must admit I was beginning to have serious doubts about your sanity...until I read your last sentence!![]()
I floated an idea on another topic, to a rather mixed reception, to use bits of HS2 for a higher-speed Transpennine route. This would comprise a Liverpool connection from Phase 2 (either new infrastructure or joining an existing line); Phase 2 Manchester branch; reversal somewhere near Piccadilly onto a reopened Woodhead line; new construction north-eastwards from near Penistone; and HS2 Phase 2 to Leeds and any northern extension to Tyneside.
I like the idea of sharing the HS2 route from Liverpool but I would prefer the Manchester HS2 station to a through east west facing station to avoid reversals for Transpennine services. I also like the idea of at least using part of the Woodhead route especially if there was Y junction near Penistone to allow trains to run to north to Leeds etc., and south to Sheffield and beyond.
Unfortunately I can't see any way of doing a through station in Manchester without either another long tunnel under the city, this time from the west, or having the station a long way out of town. If the western approach was along classic lines than this would perpetuate the capacity problem and the slower running would probably cost more time than a reversal.
I'm not sure the loss to a direct HS link from the south would lose Manchester Airport too many passengers as these could easily be offset if it was possible to build a spur from the Piccadilly/Woodhead section of the line to the airport. This would allow compatible & HS trains from the both the north, east and west to reach the airport as the HS network is developed.
The reason for the HS2 Manchester Airport station will be to serve the future international business hub that will be within the environs of the airport, that even Chinese money is being drawn into, as much as any airline passenger usage.
If someone can post a link to this international business park project, I would be most grateful.
Wouldn't skip-stopping on Transpennine kill the Ale Trail?
