New trains for East Midlands Franchise
10 Oct 2012
Or they might just not bother? I haven't actually seen 180s officially announced yet?
180s are definitely in the plan, they were confirmed in the staff presentation that has been widely referenced here and elsewhere. Whether or not it happens is another question, though.
10 Oct 2012
The only way EMR could try and cushion the blow of inheriting the class 180s thanks to the actions of their questionable bidding team, is by trying to diagram them on light duties where they're only working two peak journeys a day or something like that and spend the rest of it sitting in the depot doing nothing. Even if they fail, it will only impact very few journeys a day.
Which is exactly what the 6 car HST sets are diagrammed to do at the moment, funnily enough. I suspect the 180s will be used more intensively from Dec 2020 though, when they and the 222s will have to cover all Nottingham/Sheffield services.
Mitchell Hurd
28 Oct 2017
Which is exactly what the 6 car HST sets are diagrammed to do at the moment, funnily enough. I suspect they'll be used more intensively from Dec 2020 though, when they and the 222s will have to cover all Nottingham/Sheffield services.
I wouldn't get your hopes up - EMT tweeted to someone or 2 people that the buffered HST's will be replaced by stock displaced from Hull Trains.
The DfT is bonkers to let unreliable trains replace reliable trains. At one time, I'd be happy at 180's replacing HST's but considering the major issues with Hull Trains, the HST's should be kept going til new trains arrive!
hwl
5 Feb 2012
The IC diagramming isn't that tight is some places at the moment (especially stock rotating through a Corby turn) so some room to squeeze in addition to not having to use non EMUs for Corby might get close to elininating HST overall. Getting as many southern end EMT users on to the EMUs will be key.
hwl
5 Feb 2012
I read the comment as 180s replacing existing 6 car diagrams which are very relaxed at the moment but everything will get squeezed in December 2020 so they have a short period of time to get reliability sorted.
43074
10 Oct 2012
Yes the 2+6 sets are the buffered ones, I was implying that initially the 180s will drop onto those diagrams and be used more intensively from Dec 2020. Plus the ex Grand Central sets are the least reliable in the fleet.
talltim
17 Jan 2010
Anyone spot a pattern?
43074
10 Oct 2012
Indeed, I reckon the standard hourly service on the MML post Corby electrification could be covered with, say, 18 circuits - 10 on Sheffield services with 2 hr journey times, and 8 on Nottingham services with 1 hr 35 journey times and 25 min turnarounds. They will have 31 units in the Intercity fleet, so seven or eight circuits could still operate as pairs and leave a maintenence buffer. The timetable will be more similar in the peak to the off peak than it is now, leading to the logical conclusion that replacing HSTs is dependent on the Dec 2020 recast, but completely achievable with the mixed 222 and 180 fleet.
hwl
5 Feb 2012
I have never said that anywhere in any of my posts. It's a known fact that the leases Porterbrook have charged, particularly with the class 350/2 and 379 fleet are quite high hence they are being replaced by cheaper, new trains.
379s are Macquarie (ex Lloyds TSB) not Porterbrook.
cactustwirly
10 Apr 2013
No they won't, they're being binned next May once the 180s are in service.
43074
10 Oct 2012
That's exactly what I said, if you'd bothered to read what I'd written :rolleyes: I implied the 180s will replace them like for like.
Railperf
30 Oct 2017
Unlesa reliability can be improved, nobody in their right mind would take a 180 over an HST at the moment. It would be absoloutely madness. Order some bi-modes NOW!!
hwl
5 Feb 2012
Do-able but also dependant on getting the Kettering and further south users on to the EMUs and being able to time single units on to counter peak journeys in both peaks.
samuelmorris
18 Jul 2013
Brentwood, Essex
One thing will stop them taking 379s:
There’s 30 of them. We’ve worked out independently they need no more than 18 units a day with all 6 cycles on the Corby route being 12 car. Why would you have 12 maintenance spares instead of 3?
Moreover, it’s been confirmed they’re having 360s. Will they be able to update the incumbent cabs for 110mph? Of course they will.
No reason for them to take all 30 - 30 would be too many to bolster any of the other AC Electrostar fleets, but an extra 9 could probably slot into GN, GWR or even c2c quite easily.
43074
10 Oct 2012
Easier said than done though given heavy flows from Nottingham/Derby to Leicester in the PM peak though, I suspect crowding will remain as bad if not worse than it is now until the new stock arrives.
Doesn't really help at this stage, ought to have been done two years ago to avoid this very situation in the first place.
hwl
5 Feb 2012
Easiest to slot 9 into would be GatEx. (DC conversion is simple).
The Vampire Kangaroo are by far the least experienced ROSCO and bit detached from reality.
Howvever Anglia are expected to be short of stock so reasonable to expect some to stay from 379/321.
samuelmorris
18 Jul 2013
Brentwood, Essex
Not as simple as retaining them on AC routes for which they are already equipped. GX would also have no use for that many units, surely. As hinted, it's also possible some 379s may stick around on GA. In any case, that's speculation for another thread. If the 360/1 cab issue really is a genuine problem, I can just see them running at 100mph temporarily until something else is worked out.
hwl
5 Feb 2012
They would as only ~50% of GatEx services are 12 car with the rest 8 car. 8-9 units needed to run all as 12 car. (Half the GatEx services are Victoria Brighton)
I don't think the cab problem is a real issues just a paperwork one.
samuelmorris
18 Jul 2013
Brentwood, Essex
8-9 extra units sure, but not 30, was what I was getting at. I don't see what they'd do with them all. It'd be the same problem as trying to use them all for Corby, but probably worse.
hwl
5 Feb 2012
Hence 21 to EMR and 9 to GX but that woul need to much joined up thinking.
Coastway as the SN 313 need replacing in the next few years... 20+ units needed
SN 455 replacement too.
4-SUB 4732
7 Jan 2018
And this is why I'm glad Rail UK isn't where the ideas come from at Westminster. Why split a fleet of 30 units, which can have battery tech added, into a 21 and a 9? Terrible!
samuelmorris
18 Jul 2013
Brentwood, Essex
Plenty of ideas that came from Westminster or the TOCs themselves have involved splitting or joining fleets before - look at basically all the Sprinter classes, 170s, 321s, 317s, 377s and so on. A split fleet is better than one sitting in storage gathering dust.
