I know the reason why some passengers get so obsessed about 'end doors' on trains, but given that the use of 23m stock like the 444s has resulted in all desiros being limited to 40mph, why does the TOC not explain to them that their craving for the 444s causes an everlasting extension to journey times for all direct line passengers south of the tunnel (i.e. even if they 'suffereing' travelling in 20m cars with 1/3 2/3 doors.
If the 458s remove all 444s from the direct line, the speed limit through the tunnel could be lifted for alll trains. When the pressure groups start whingeing about the change they should be made aware of the removal of the self-imposed degrading of the service.
Whilst I largely agree with the sentiments of this, I’m not sure banning 444s from the line would be viable. At the very least the line is a diversionary route for Guildford to Eastleigh / Southampton, and as such 444s will need to go down there from time to time. I don’t think that could be removed without imposing undue inflexibility on the railway as a whole.
I don’t think it’s the end doors which are the big bugbear for the Portsmouth Direct users to be honest. The big issue is the 3+2, and mainly facing layout, the consequence of which presumably means there squashed in for a long(ish) journey, which wouldn’t be the case on a 444.
As I’ve said elsewhere, to be fair I don’t think this gripe is entirely unreasonable, but could be solved by having a dedicated fleet of 450s (or 458s, as is presumably happening) with a slightly less dense layout. If they *then* start moaning about the door positions then that’s another matter entirely and I’d lose sympathy!
It isn’t like the line has been lavished with new stock over the years, they waited their turn for the CIGs to be replaced (not that personally I’d moan about having to commute on those!), got their new trains for a few years and then has then taken away to allow the 442s to be removed. So all in all it’s probably fair to say it hasn’t been the best deal.
(I should add that this isn’t a route I use nor have any association with, so I don’t have any vested interest except as an observer - indeed from a selfish point of view on off-peak lightly loaded trains I’d prefer a 450!).
