Whistler40145
Now that both Northern and TransPennine Express are government owned companies, should they be merged into one with a totally new management structure?
It would be better to break up TPE and pass its longer distance "prestige" services to other operators:Now that both Northern and TransPennine Express are government owned companies, should they be merged into one with a totally new management structure?
TPE will remain its own separate entity.Now that both Northern and TransPennine Express are government owned companies, should they be merged into one with a totally new management structure?
Why?It would be better to break up TPE and pass its longer distance "prestige" services to other operators:
Some things with this. Liverpool to Cleethorpes yes with the crew section at Cleethorpes being EMR.I would also transfer the local Northern services from Sheffield to Lincoln and Sheffield to Nottingham to EMR.
- Liverpool to Cleethorpes - to EMR
It gives the opportunity to gut the current management.Why?
TPEs issues are due to traincrew only signing a small part of the journey with many crew changes. And traincrew only signing a limited amount of rolling stock.
This wouldn't be fixed by breaking up TPE.
I think it's due to seeing the North West and North East as 2 clear areas which are separated from each other due to the lack of connection between them (due to Geography).I don't get this obsession with redrawing the operator map in the North, as if it would be a magic bullet that would solve all the issues.
Rearranging the deckchairs on the Titanic springs to mind.
Newcastle - Carlisle?I think it's due to seeing the North West and North East as 2 clear areas which are separated from each other due to the lack of connection between them (due to Geography).
I know right. Splitting out some of the services to other operators who just happen to operate in the areas won't solve anything, multiple operators taking over sections on the edges of their usual operations will lead to only one thing. The first services to be canned will be those on the edges. You can see it coming a mile off.I don't get this obsession with redrawing the operator map in the North, as if it would be a magic bullet that would solve all the issues.
Including both Leeds-Carlisle and Leeds-Lancaster when they are common over the main section which is Leeds-Settle Junction. I'd say the link portion is Skipton to Hellifield.Newcastle - Carlisle?
Leeds - Carlisle?
Leeds - Lancaster?
York - Blackpool?
Calder Valley?
Manchester - Sheffield?
Do these routes provide not enough links between east and west for you?
The railway industry already sees enough departmental reorganisations every x years. Please don't speculate on the possibility of more!Now that both Northern and TransPennine Express are government owned companies, should they be merged into one with a totally new management structure?
The big issue that that split is not really clear at all across the UK railway.Finally, there would also be a clearer split between "local" and "regional/inter-city" services, allowing things like ticketing/branding to be adjusted accordingly.
Couldn't have summed it up better myself.With TPE the crewing arrangements are like a house of cards being built in the inter-car connection of a 142 with severe wheel flats
Please clarify the following from your sweeping statement with zero substance or backing.Would the simplest resolution be to replace the existing top management at Northern?
Do you own Northern?Please clarify the following from your sweeping statement with zero substance or backing.
A) Why? Zero reasons given
B) Who? How far down the structure are you planning (assuming you know the detail of Northern’s management structure).
C) How? How do you propose the implementation of your management overhaul and how it would improve things without intermediate disruption while this happens.
It does concern me when people make sweeping statements like this and don’t give reasons and solutions. It’s just totally baseless and smacks of lack of knowledge of how the railway runs
No but I work for them, 32 years and counting. I’d just like to know what you mean by ‘replacing the top management’, reasons why, how it should be done etc.Do you own Northern?
Why put trains into the timetable that the company has nil chance of covering, surely it would be far more sensible to operate a limited timetable, rather than lots of cancellations and leading to lots of Delay Repay requests when passengers are inconvenienced when services are cancelled at short noticeNo but I work for them, 32 years and counting. I’d just like to know what you mean by ‘replacing the top management’, reasons why, how it should be done etc.
However judging by, what I consider an irrational response to my questions, I suspect you’re trying to sound clever with zero substance for it. I think we’ll just leave it there unless you can answer my questions rationally.
Ok, that’s a few questions explained on many threads by staff shortages which is hardly exclusive to Northern so please explain what ‘replacing top management’ immediately achieves and how you think the changeover should be implemented without affecting anything. I’m intrigued.Why put trains into the timetable that the company has nil chance of covering, surely it would be far more sensible to operate a limited timetable, rather than lots of cancellations and leading to lots of Delay Repay requests when passengers are inconvenienced when services are cancelled at short notice
It wasn’t due to performance.Like TransPennine Express, Northern was taken back by the Government, so something was wrong
The MD and associated management don't need changing. Golton was a competent MD what had his hands tied behind his back.It gives the opportunity to gut the current management.
I understand, especially when the Windermere and Barrow in Furness services and associated staff were TUPEd to NorthernThe MD and associated management don't need changing. Golton was a competent MD what had his hands tied behind his back.
The relationship issues between management and staff run deeper into the lower management who would be TUPEd across in a TOC change anyway
