Northern Class 195: Construction/Introduction Updates
Aivilo
15 Jan 2014
It's actually a pig to get out of from a drivers perspective as the ladder is tucked under the body
EE Andy b1
12 Dec 2013
CLC
Does look quite a tricky climb down from cab to track level on the Class 195, as you say the steps are tucked away and the initial step is quite high compared to a Class 221.
Both about the same to platform level.
tn_gb-northern-class195 (2).jpg Bombardier_Virgin_Supervoyager_Class_221_No_221142_(-125113751).jpg
lammergeier
5 Oct 2017
The set up is more akin to the 220 which has a body mounted ladder and as such is more awkward for access/egress than the bogie mounted 221.
EE Andy b1
12 Dec 2013
CLC
Never even thought about Class 220 with body mounted steps. Spot on! Never get on and off them, cab wise. :rolleyes:
So yep more akin the 195.
EE Andy b1
12 Dec 2013
CLC
Is everything good now between unions ASLEF/RMT and Arriva over these units and has a proper training package been worked out now for Drivers and Guards?
EE Andy b1
12 Dec 2013
CLC
Training has resumed
Good training has resumed, testing has resumed so come on Northern let's get some 195s into service where needed and lets get rid of some of the crap (142s for starters) that Northern passengers have had to put up with for years longer than they should have.
Really frustrating that nobody seems that bothered how long these things are taking to be introduced.
Mathew S
7 Aug 2017
As has been pointed out several times, by several people, they cannot enter service until the internal coupler defect has been rectified. Lots of people are very bothered indeed - not least Northern - but making them safe for passenger use, not to mention training enough crews to operate the things, takes however long it takes.
EE Andy b1
12 Dec 2013
CLC
Yes we know about the vehicle fixed coupler defects and these should be getting rectified on later build sets then retrofitting to the earlier builds which are again being used for training. When the later modified units arrive get them into service first then modify the others. Should be enough train crews trained up by then to get some into service where they are needed.
td97
26 Jul 2017
Take a quick look through their profile page, and it's a reasonable conclusion that the poster is a driver who's clued-up with what happens in the industry. The answer to the rest of your query is probably commercially sensitive.
driver_m
8 Nov 2011
I congratulate you on not giving a sarcastic or equally rude reply back to the poster. I wouldn’t give them any response for asking like that.
_toommm_
8 Jul 2017
I digress. Some people are just straight talking and don't employ much in the way of rhetoric.
Aivilo
15 Jan 2014
Internal. Similar to the stack issues on the 769 the coaches need to be slightly further apart. Probably doesn't take a genius to work out what has been put on place
I did think they looked very close together, very much like square-ended UIC stock. But then Pendolinos are the same. Is it the actual coach ends that are fouling? I thought it was coupler bar against body because the slot it moves in isn't quite wide enough.
krus_aragon
10 Jun 2009
North Wales
I'm speaking with no insider knowledge, but if the coupler bar were too short, that could mean that the coach ends were fouling against each other on tight curves. A longer coupler (along with the flexibility of the corridor connection) could overcome that, if it were the case.
LOL The Irony
29 Jul 2017
Chinatown, New York
From what we've managed to gather, the gap on the mounting brackets is too small, not the bar.
37201xoIM
29 Apr 2016
For what it's worth, I understand that the December 2019 Calder Valley timetable is based on 195s working the Leeds - Man Vic and Leeds - Man Vic - Chester services plus the York - Blackpool, though not the LDS - Dewsbury - Calder - MCV - Wigan nor those not serving the Upper Valley. And it seems that the sectional running times take account not only of the LSIs that have been delivered west of Bradford but also of the improved performance of the 195s (so there are JT improvements between Leeds and BDI)...
So we had better keep our fingers crossed that enough are serviceable by then, or there will be, ahem, "challenges"!
scrapy
15 Dec 2008
Rumour is September for these to be out in passenger service. Will try to confirm soon
I have heard from Monday 1st July it is hoped to have a 195 in passenger service on at least 1 Barrow to Manchester Airport diagram. Likely 06.47 from Barrow. Whether or not this will happen or if this is the 1st 195 in passenger service remains to be seen.
