Northern issue - train becoming uncoupled near Hull
Mollman
21 Sep 2016
Apologies if covered elsewhere but does anyone have further details on an issue in the Hull area? Northern journey check has a number of services being disrupted for the same reason as below
10:56 Bridlington to York due 12:48 will be started from Hull.
It will no longer call at Bridlington, Nafferton, Driffield, Hutton Cranswick, Beverley and Cottingham.
This is due to a coach becoming uncoupled on a train.
10:57 Sheffield to Scarborough due 13:43 has been previously delayed, has been further delayed at Meadowhall and is now 12 minutes late.
This is due to a coach becoming uncoupled on a train earlier today.
Thanks
Horizon22
Jobs & Careers
8 Sep 2019
Perhaps it is related to a freight train in the area?
CarrotPie
18 Mar 2021
̶F̶i̶n̶l̶a̶n̶d̶ Northern Sweden
24 Nov 2019
Are they being economical with the truth saying a Broken Down train, rather than a divided train? Suppose it is better for the public
Probably more the usual attempt to say something accurate, yet also understandable for Joe Public. After all, if it’s divided, it’s certainly also broken down!
Mcr Warrior
8 Jan 2009
Presumably this particular "mishap" didn't only affect Northern services?
Then why say a "coach" has become uncoupled?
Probably because the information operators select from a menu of possible incidents, and that’s the first option they come too. But you’re right, the thread title and initially quoted info will always make it look as if a passenger train problem for Northern.
68001
9 Jan 2019
train involved was 6D94 masborough-hull heddon road sidings this apparently is the 3rd time the train has divided
in the same area
WAB
27 Jun 2015
Middlesex
I don't think there is a DARWIN delay code for anything other than coaches being decoupled?
That’s the sort of thing I was thinking of, I think it’s been discussed here before that certain obvious events aren’t covered that well.
Deepgreen
12 Jun 2013
Betchworth, Surrey
It's more ridiculous to call it a "coach", which strongly implies a passenger train. Why on earth not put 'a wagon from a freight train'? How hard would it be to add the code to the options? It would be more accurate and far less alarming for passengers! The railway's once-great information reputation continues to slide.
JD2168
11 Jul 2022
Sheffield
in the same area
This sounds a bit concerning if it is the 3rd time it has divided in the same area, looks like it needs investigating to come up with solution to this.
WAB
27 Jun 2015
Middlesex
Because it requires negotiation and someone to care (as well as the need to update PIS announcements etc.). I understand that the 'delayed due to congestion' only came about because the TOCs kept ascribing any delays from congestion to 'delayed by late-running freight train' and the FOCs were getting fed up.
Lemmy282
8 Apr 2021
Sheffield
Apparently after the first two incidents it was determined there was a dip in the track and Network Rail put a temporary speed restriction on, and everything was okay. That restriction has been removed, and lo and behold another divided train.
philthetube
5 Jan 2016
certainly broken into 2 halves. :D
cm39275
22 Dec 2011
bicester
This image has appeared on BBC Humberside Facebook page
