Northern Short Forming Again
MichaelTrains
9 Jun 2022
Bradford
Currently at Bradford Interchange on the delayed 18:04 which is leaving passengers behind on the platform once again.
Why do Northern run inadequate two-car 195s on what effectively is a popular Leeds-Bradford-Manchester market?
This simply would not happen anywhere else in the country.
Are Northern that short of units that they must continuously short-form busy services?
Adam0984
18 Feb 2014
Short, sweet but correct. And with the Calder Valley the 2 car will hit the peak somewhere so no ideal location, at least out of Leeds you've got the 1757 Bpool that stops at Pudsey, Bradford, Halifax, Sowerby and Hebden before parting ways
sd0733
7 Nov 2012
Unfortunately, it happens in pretty much every single area of the country, there's booked small and shortformed trains everywhere that end up leaving people behind, many of them on routes less frequent than services through Bradford.
Moonshot
10 Nov 2013
If a Northern service is booked as a 4 car unit but one of the units has a fault which precludes it from operating service, should the service be cancelled or run with just a 2 car unit?;
Geeves
6 Jan 2009
Rochdale
Northern have had 5 units sent away to cover other areas of the country and must have around 15 to 20 units stopped on various works and that includes 195s having their engines rebuilt. Then there's the 769s... Oh yes the 156s that came from EMR are knackered after being thrashed across country for years on end
td97
26 Jul 2017
It is leaf fall season which is notorious for requiring trains to be removed from service to resolve wheel flats.
When are the TfW loaned 150s due back?
Is that an expected maintenance procedure after 4 years of service?
MichaelTrains
9 Jun 2022
Bradford
Obviously, you run the 2-car service but I’ve known things as bad as they currently are.
skyhigh
14 Sep 2014
Though it's not nearly as bad now everything is WSP fitted
Given the rough life there are always engine replacements/rebuilds going on any fleet. The question here is are engines living out the expected number of run hours...
CrossCountry says hello.
Jamesrob637
12 Aug 2016
Bumping this thread as it's one of the oldest not to have been locked, yet still very relevant to thousands of Northern commuters, including those affected by the recent 331 transfers.
pokemonsuper9
20 Dec 2022
Greater Manchester
Yes, on the Manc side there's definitely some issues.
A lot of the Airport-Blackpool are 4 cars, when 6 car is really needed at this point (especially so for peak time).
And to allow Airport-Blackpool to be 6 car there's DMUs running an EMU diagram (on a peak time only Wigan-Manchester)
Hopefully the 730s enter service soon so that the 323s can head up here.
MichaelTrains
9 Jun 2022
Bradford
I'd go as far to say Northern running 2 car 195s on the busy Leeds to Manchester Calders is disgraceful.
Why aren't these services all four car minimum?
I’m fed up of leaving Victoria crush-loaded.
sportzbar
11 May 2014
All services on the Calder Valley via Halifax are booked as either 3 or 4 car but unfortunately as trains are mechanical beings they can on occasion be taken out of service to fix things. Surely it's better to run a 2 car than cancel the service altogether?
Bovverboy
1 Dec 2013
Is it better to short form a train than to keep a couple of spare sets to cover 'eventualities'?
sportzbar
11 May 2014
But then surely if you keep a couple of "spare sets" then more short forming will happen. Most TOCS are short of units and would love to have just that. Spare sets than they can drop into service when something goes wrong.
Occasionally the stars align and a spare set can be found. Only a few weeks ago a 4 car set on the Chester-Leeds service developed a fault on the rear unit. On arrival at Victoria it was met on platform 6 with that "spare unit" which was attached whilst the rear unit was uncoupled and taken for attention.
But this is quite rare and having spare sets sat around not earning money just doesn't make financial sense....
Bovverboy
1 Dec 2013
td97
26 Jul 2017
The other major issue is overcrowding on services which are booked an insufficient length. Blackburn to Rochdale as 2 carriages is one example.
Is the unit that had the alternator fire last autumn still out of service?
AMD
6 Dec 2017
Through choice.
There is also the element of how much can be afforded to have lying about spare, bearing in mind that Northern is arms length govmnt owned so the treasury has a hand in the background. As an example a 156 unit costs around £4k a WEEK in leasing charges, then there's fuel, parts, maintenance etc to keep it road worthy, so that's a lot of £3.50 advance singles from Victoria to Rochdale to sell to pay for it!
There is a couple of issues with waiting parts (especially the 331s out of Allerton) at the moment which is stretching the fleet a bit more than usual.
Bovverboy
1 Dec 2013
The government ultimately decides everything, irrespective of whether the TOC is directly government controlled or not.
You don't incur fuel, parts, and maintenance costs to keep a unit spare, only if you decide to use it.
Reason to keep a couple of units spare?
skyhigh
14 Sep 2014
Theoretically the fleet is sized to have spare units based on normal usage.
However, availability isn't great at the moment due to a mixture of CAF issues and mods in progress so there are more units stopped than planned.
northwichcat
4 Mar 2023
Northwich
Fares within a PTE area are generally lower than the Northern average.
Chester to Delamere is £7.20 single and £8.50 or £10 return for a journey that's 9 miles each way.
Bovverboy
1 Dec 2013
Exactly, to which the solution is to either short-form trains or cancel them altogether. Short-formed and cancelled trains will always be with us, it's a feature of the current franchising system.
MichaelTrains
9 Jun 2022
Bradford
I disagree with the person who says all Leeds to Manchester via the Calder are all 3/4 car.
It's either 2 car or 4 car from what I experience and it’s no fun having to stand for 30/40 minutes to or from Manchester on a crush loaded 195.
Geeves
6 Jan 2009
Rochdale
In my experience control (at Northern) will try and add the missing carriages back if they can. I don't think theres a conspiracy to short form on purpose. The 195s are currently down due to engine rebuilds, also legacy units are being used on what should be electric work in the NW. Northern won't keep units spare for the sake of it and the government isn't involved at such a micro management level thankfully. I just have visions of a man from the Treasury sat in control!
Bovverboy
1 Dec 2013
I think Sportzbar's point was that the Calder Valley 195 are booked 3 or 4 car, he wasn't challenging the notion that they often turn up as 2-car. If you never see a 3-car set, it may be that the standard formation is 4-car, even if often reduced to 2-car.
