Northern Wakefield Westgate to Huddersfield Saturday allocations
Class455
19 May 2016
I'm due to travel to Huddersfield tomorrow and travelling on Northern for the first time using their Wakefield Westgate to Huddersfield service both ways. I was wondering, what is generally the allocation for these services on a Saturday?
The service that I'm due to travel on both ways (2O72 and 2O83) is booked for a Pacer (according to Realtime Trains), but after seeing pictures, it looks like 150's generally do these services. I'm really hoping I don't have to suffer with a Pacer after everything that I've seen and heard about them and would much prefer a Class 150, especially since they are similar to a 455.
Loop & Link
22 Feb 2015
2O72 booked to be a Class 155. 2O83 booked to be a Class 150. Hope this helps.
PHILIPE
14 Nov 2011
Caerphilly
Just a reminder, RTT does NOT show what is booked so please don't rely on it. It shows you the timings used for the train and anything that can maintain those can actually be booked on it.
...The service that I'm due to travel on both ways (2O72 and 2O83) is booked for a Pacer (according to Realtime Trains)....
That's not the case. The open data used by sites such as Open Train Times, Realtimetimetrains etc merely shows timing loads.
The open data does not currently show the booked stock, however in the case of some train companies, the timing load can give a very good indication of what sort of stock is likely to be allocated, but that is certainly not the case here.
61653 HTAFC
18 Dec 2012
Another planet...
Weekdays the Huddersfield to Wakefield service is solid 2-car pacer territory, with the odd 150 on rare occasions. On Saturdays a 155 is regular, with 150s also more likely than during the working week.
Using anything bigger than a 150 is a slight risk, in the event of anything going bottom-over-bosom at HUD, due to the restricted length of Platform 5.
NorthernSpirit
21 Jun 2013
When I've used it I've either ended up with a 142, 144 or a 150. All depends on Northerns random unit generator.
Crossover
4 Jun 2009
I think 153's can be on it too (I recall they were commonplace after it was split from the Selby/Leeds to Huddersfield via Bradford Grand Tour). Very occasionally the service ends up with a 158, too
So yes, take your pick from 142, 144, 150, 153, 155 or 158!
Class455
19 May 2016
Thanks all for your responses! Looking forward to using Northern for the first time and to see what I get tomorrow after my VTEC train from King's Cross. Just hoping my services are NOT Pacers. Would be interesting to try out a Class 153/155 considering as there are none down south, what are they like onboard? I'm hoping for a 150 though, as I've never had one and as I said in the original post, are most like the 455's.
Bovverboy
1 Dec 2013
You really ought to try a Pacer, they're not nearly so bad as they're portrayed.
Crossover
4 Jun 2009
I'm sure you will be glad to know the two services you have mentioned aren't the same diagram. Had you been an hour earlier going back, however, you'd have likely had the same unit both ways!
