Oil lamps - what oil?
M7R
15 Sep 2010
I have just got a BR Midland oil lamp that’s fully working (so the ad said).... and fancy using it in the evenings as a table lamp outside, maybe... but what oil do they burn? As I’m guessing filling them with Castro’s GTX isn’t the best idea :lol:.
Anyone else got any old oil lamps they still use? Any tips or advice?
hexagon789
2 Sep 2016
Something called lamp oil (refined from petroleum) which had additives to prevent soot build up.
Paraffin was also used but this has a tendency to produce a lot of dark smoke and soot, camphor was sometimes added to paraffin to reduce the sootiness, but lamp oil was preferred.
You should be able to get “lamp oil” from a decent hardware store or camping shop. I used to buy it a few years ago for a paraffin lamp used on a narrow boat. Much cleaner than paraffin. Just googled it and the Robert Dyas chain sells it, for example.
M7R
15 Sep 2010
I did think paraffin, but also remembered that being a bit smokey when I have seen it burnt before.
I will have a look and see if I can get proper lamp oil close to where I live, there’s a boat yard so that maybe a start.
I also wasn’t sure if lamp oil was just a name or an actual grade of oil so to speak...
trainmania100
8 Nov 2015
Newhaven
A litre of petrol from your local gas station probably the quickest and cheapest resolution
Moderator note: the above 'advice' is completely incorrect
John Webb
5 Jun 2010
St Albans
NO! NO! NO! Petrol is too flammable for use in these lamps. It will rapidly release vapour from the wick and there is a significant risk that on trying to light the lamp the build-up of vapour would cause an explosion with serious damage to the person applying the light, to say nothing of destroying the lamp.
Paraffin and other "lamp oils" have a much higher 'flash-point' and release vapour at a relatively slow rate, avoiding the build-up of an explosive mixture.
I would also recommend that the container is checked by filling with water prior to filling with paraffin to ensure there are no leaks.
trainmania100
8 Nov 2015
Newhaven
Thanks for clearing that up
John Webb
5 Jun 2010
St Albans
Can't be that much difference between petrol and paraffin?
Enormous - the 'Flash-point' of petrol; a measure of the ease of igniting it, is -46degC; for paraffin it is between +27 and +74degC depending on the exact type of paraffin.
(I used to be a scientist working at the Fire Research station - petrol fires were lit preferably by a remotely operated ignition source while paraffin fires usually had to have a small area heated by petrol before the paraffin would ignite.)
ChiefPlanner
6 Sep 2011
Herts
To recall an anecdote from the late , G Fiennes (an excellent high powered railwayman) - in WW2 he was called out to a derailment on the Great Central , so he filled his handlamp in the garage with what he assumed was lamp oil. Walked to the station in the blackout and boarded a light engine to take him to the incident.
Once on the move , he lit the handlamp and sat down - luckily away from the lamp - which suddenly exploded.
GF's comments were that the Leicester driver merely said , without turning round "that's bloody good paraffin" - it apparently took a lot to shake them up !
M7R
15 Sep 2010
Couldn't you burn citronella oil to keep the midges away..?
Funnily enough after I realised that I had been a little silly and should have just googled Lamp Oil, rather than what oil for an oil lamp.... I have been looking around and on amazon there is citronella scented lamp oil, so that’s an option
jmh59
7 May 2018
We have a drum of lamp oil stored at the railway - I'm not there for a couple of weeks but if I get a chance I'll see what all the labels say.
John Webb
5 Jun 2010
St Albans
I think 'Lamp Oil' is Kerosene, one of the cleanest forms of paraffin, but can't be certain on that. And I know we use paraffin at St Albans South for our lamps but uncertain what grade - and unable to check at the moment.
Most online sources reckon it’s the other way around, paraffin is cleaner than kerosene.
scott118
24 Feb 2015
East Anglia
Places like B&Q, Homebase, & various supermarket chains sell the stuff too.
M7R
15 Sep 2010
Well every day is a school day! Rather looking forward to my lamp arriving,
Ken H
11 Nov 2018
N Yorks
er?
Isnt kerosene aviation fuel?
